(2014-05-02, 23:37)wolfgar Wrote: [ -> ]No not yet sorry : it is one of the 2 remaining big issues with imx6 (the other being HD audio)
wolfgar, I just want to mention that I convinced rabeeh @ solid-run to seed Anssi with a cubox-i to work on the HD audio for imx6.
Maybe you could have a bit of discussion with Anssi on #cubox to bring him up to speed. fritsch indicated that Anssi is strong on Alsa.
(2014-05-18, 17:29)wolfgar Wrote: [ -> ]Hi
Thank you very much cbxbiker61
I have just opened a ticket on github to centralize and make a point regarding HD audio work for imx6 : https://github.com/xbmc-imx6/xbmc/issues/68
Regards
Stephan
So you get it to work now. That's really cool. Cant wait to test this when I get my CuBox-i4Pro.
Hi JoZerByte
It seems that I have the same issue (utilite and cuboxi tested...)
I installed latest xbmc-imx-git 13.20140506-1 on wandboard quad(archlinuxarm), when I click the power button and want to shutdown/reboot the system, I found that there is just a "Exit" item in the menu, the others disappeared.
this is the user xbmc:
[root@alarm ~]# id xbmc
uid=1000(xbmc) gid=1000(xbmc) groups=1000(xbmc),6(disk),90(network),91(video),92(audio),93(optical),95(storage),98(power)
Is there anything that I missed?
hi, i have the following problem on my Cubox I2-Ultra:
1. My DVB-S2 Tuner doesn't load (Tevii S660)
2. My e-sata external HDD doesn't load
lsusb:
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg:
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.10.30 (geexbox@SolidRun-PC) (gcc version 4.8.3 20140401 (prerelease) (Linaro GCC 4.8-2014.04) ) #1 SMP Mon Aug 4 11:35:03 IDT 2014
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: SolidRun Cubox-i Dual/Quad
cma: CMA: reserved 256 MiB at 40000000
Memory policy: ECC disabled, Data cache writealloc
On node 0 totalpages: 262144
free_area_init_node: node 0, pgdat 80884600, node_mem_map 808eb000
DMA zone: 2048 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 262144 pages, LIFO batch:31
PERCPU: Embedded 8 pages/cpu @81100000 s8512 r8192 d16064 u32768
pcpu-alloc: s8512 r8192 d16064 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait rw consoleblank=0 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=16 dmfc=3
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
allocated 2097152 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 1024MB = 1024MB total
Memory: 765556k/765556k available, 283020k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807f4d04 (8116 kB)
.init : 0x807f5000 - 0x80833140 ( 249 kB)
.data : 0x80834000 - 0x80885700 ( 326 kB)
.bss : 0x80885700 - 0x808eafb8 ( 407 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
RCU debugfs-based tracing is enabled.
Additional per-CPU info printed with stalls.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x72070000, Cache size: 1048576 B
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
CPU identified as i.MX6Q, silicon rev 1.2
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys blkio
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x805d0e80 - 0x805d0ed8
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3162.11 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1125 mV
vdd3p0: 2800 <--> 3150 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2425 mV
cpu: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV at 1150 mV
vddsoc: 725 <--> 1450 mV at 1200 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
brcm_osc_reg: 3300 mV
brcm_reg: 3300 mV
3P3V: 3300 mV
usb_h1_vbus: 5000 mV
usb_otg_vbus: 5000 mV
vgaarb: loaded
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-2: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC ONLY-DP HIGH RESOLUTION: 5B(0~3), 5F(4~7)
imx-ipuv3 2800000.ipu: IPU DMFC ONLY-DP HIGH RESOLUTION: 5B(0~3), 5F(4~7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
hw perfevents: enabled with ARMv7_Cortex_A9 PMU driver, 7 counters available
pureg-dummy: no parameters
imx6_busfreq busfreq.13: DDR medium rate not supported.
Bus freq driver module loaded
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 2007
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: WEIM driver registered.
mxc_sdc_fb mxc_sdc_fb.28: register mxc display driver hdmi
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
Console: switching to colour frame buffer device 240x67
imx-sdma 20ec000.sdma: loaded firmware 1.1
imx-sdma 20ec000.sdma: initialized
Serial: IMX driver
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled
mxc_hdmi 20e0000.hdmi_video: mxc_edid_read_internal
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
ahci: SSS flag set, parallel bus scan disabled
ahci ahci: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
CAN device driver interface
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
imx_usb 2184000.usb: usbmisc init failed, ret=-517
platform 2184000.usb: Driver imx_usb requests probe deferral
imx_usb 2184200.usb: usbmisc init failed, ret=-517
platform 2184200.usb: Driver imx_usb requests probe deferral
mousedev: PS/2 mouse device common for all mice
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
rtc-pcf8523 2-0068: rtc core: registered rtc-pcf8523 as rtc0
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
i2c /dev entries driver
Registered IR keymap rc-empty
input: gpio_ir_recv as /devices/soc0/ir-receiver.22/rc/rc0/input0
rc0: gpio_ir_recv as /devices/soc0/ir-receiver.22/rc/rc0
mxc_v4l2_output v4l2_out.31: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.31: V4L2 device registered as video17
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
mmc0: no vqmmc regulator found
sdhci-esdhc-imx 2190000.usdhc: lookup for GPIO card-reset failed
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc1: no vqmmc regulator found
mmc0: queuing unknown CIS tuple 0x80 (50 bytes)
mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
mmc0: queuing unknown CIS tuple 0x80 (4 bytes)
mmc0: queuing unknown CIS tuple 0x02 (1 bytes)
mmc0: new SDIO card at address 0001
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
mmc1: host does not support reading read-only switch. assuming write-enable.
mmc1: new high speed SDHC card at address e624
mmcblk0: mmc1:e624 SU08G 7.40 GiB
mmcblk0: p1 p2
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-8: ST3000DM001-1CH166, CC44, max UDMA/133
ata1.00: 5860533168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA ST3000DM001-1CH1 CC44 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
sd 0:0:0:0: [sda] 4096-byte physical blocks
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI disk
Galcore version 4.6.9.9754
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_asrc 2034000.asrc: mxc_asrc registered
mxc_vpu 2040000.vpu: VPU initialized
mxc_hdmi_cec hdmi_cec.15: HDMI CEC initialized
caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
caam 2100000.caam: job rings = 2, qi = 0
caam 2100000.caam: authenc-hmac-md5-cbc-aes-caam
caam 2100000.caam: authencesn-hmac-md5-cbc-aes-caam
caam 2100000.caam: authenc-hmac-sha1-cbc-aes-caam
caam 2100000.caam: authencesn-hmac-sha1-cbc-aes-caam
caam 2100000.caam: authenc-hmac-sha224-cbc-aes-caam
caam 2100000.caam: authencesn-hmac-sha224-cbc-aes-caam
caam 2100000.caam: authenc-hmac-sha256-cbc-aes-caam
caam 2100000.caam: authencesn-hmac-sha256-cbc-aes-caam
caam 2100000.caam: authenc-hmac-md5-cbc-des3_ede-caam
caam 2100000.caam: authencesn-hmac-md5-cbc-des3_ede-caam
caam 2100000.caam: authenc-hmac-sha1-cbc-des3_ede-caam
caam 2100000.caam: authencesn-hmac-sha1-cbc-des3_ede-caam
caam 2100000.caam: authenc-hmac-sha224-cbc-des3_ede-caam
caam 2100000.caam: authencesn-hmac-sha224-cbc-des3_ede-caam
caam 2100000.caam: authenc-hmac-sha256-cbc-des3_ede-caam
caam 2100000.caam: authencesn-hmac-sha256-cbc-des3_ede-caam
caam 2100000.caam: authenc-hmac-md5-cbc-des-caam
caam 2100000.caam: authencesn-hmac-md5-cbc-des-caam
caam 2100000.caam: authenc-hmac-sha1-cbc-des-caam
caam 2100000.caam: authencesn-hmac-sha1-cbc-des-caam
caam 2100000.caam: authenc-hmac-sha224-cbc-des-caam
caam 2100000.caam: authencesn-hmac-sha224-cbc-des-caam
caam 2100000.caam: authenc-hmac-sha256-cbc-des-caam
caam 2100000.caam: authencesn-hmac-sha256-cbc-des-caam
caam 2100000.caam: ecb-des-caam
caam 2100000.caam: ecb-arc4-caam
caam 2100000.caam: ecb-aes-caam
caam 2100000.caam: ctr-aes-caam
caam 2100000.caam: cbc-aes-caam
caam 2100000.caam: ecb-des3-caam
caam 2100000.caam: cbc-3des-caam
caam 2100000.caam: cbc-des-caam
caam 2100000.caam: fsl,sec-v4.0 algorithms registered in /proc/crypto
platform 2101000.jr0: registering rng-caam
platform caam_sm: caam_sm_test: 8-byte key test match OK
platform caam_sm: caam_sm_test: 16-byte key test match OK
platform caam_sm: caam_sm_test: 32-byte key test match OK
platform caam_secvio.32: security violation service handlers armed
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver r8712u
imx-spdif sound-spdif.26: dit-hifi <-> 2004000.spdif mapping ok
imx-audio-hdmi sound-hdmi.27: hdmi-hifi <-> hdmi_audio.14 mapping ok
TCP: cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
8021q: 802.1Q VLAN Support v1.8
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
lib80211_crypt: registered algorithm 'WEP'
lib80211_crypt: registered algorithm 'CCMP'
lib80211_crypt: registered algorithm 'TKIP'
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
registered taskstats version 1
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
rtc-pcf8523 2-0068: setting system clock to 2014-08-05 23:31:10 UTC (1407281470)
ALSA device list:
#0: imx-spdif
#1: imx-hdmi-soc
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 248K (807f5000 - 80833000)
usb 1-1: new full-speed USB device number 2 using ci_hdrc
systemd[1]: Failed to insert module 'ipv6'
input: Logitech USB Receiver as /devices/soc0/soc.1/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1:1.0/input/input1
hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ci_hdrc.0-1/input0
input: Logitech USB Receiver as /devices/soc0/soc.1/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1/1-1/1-1:1.1/input/input2
hid-generic 0003:046D:C52B.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ci_hdrc.0-1/input1
hid-generic 0003:046D:C52B.0003: hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-ci_hdrc.0-1/input2
usb 2-1: new high-speed USB device number 2 using ci_hdrc
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR NEC protocol handler initialized
IR Sony protocol handler initialized
input: MCE IR Keyboard/Mouse (gpio-rc-recv) as /devices/virtual/input/input3
IR MCE Keyboard/mouse protocol handler initialized
IR SANYO protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
lirc_dev: IR Remote Control driver registered, major 245
rc rc0: lirc_dev: driver ir-lirc-codec (gpio-rc-recv) registered at minor = 0
IR LIRC bridge handler initialized
systemd-udevd[149]: starting version 210
systemd-journald[138]: Received request to flush runtime journal from PID 1
cfg80211: Calling CRDA to update world regulatory domain
brcmfmac: brcmf_sdio_chip_drivestrengthinit: No SDIO Drive strength init done for chip 4329 rev 3 pmurev 6
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Sep 2 2011 14:48:19 version 4.220.48
brcmfmac: brcmf_fil_cmd_data: Failed err=-23
brcmfmac: brcmf_fws_init: failed to set bdcv2 tlv signaling
ERROR: v4l2 capture: slave not found!
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCILL protocol initialized
Bluetooth: HCIATH3K protocol initialized
Bluetooth: HCI Three-wire UART (H5) protocol initialized
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
fec 2188000.ethernet eth0: Freescale FEC PHY driver [Atheros 8035 ethernet] (mii_bus:phy_addr=2188000.ethernet:04, irq=-1)
libphy: 2188000.ethernet:04 - Link is Up - 100/Full
usb 2-1: device descriptor read/64, error -110
usb 2-1: new high-speed USB device number 3 using ci_hdrc
usb 2-1: new high-speed USB device number 4 using ci_hdrc
usb 2-1: device descriptor read/8, error -110
usb 2-1: new high-speed USB device number 5 using ci_hdrc
hub 2-0:1.0: unable to enumerate USB device on port 1
It's a clean installed geexbox-devel-20140804-r811bdba.cuboxi.img.xz
3. The Internet Streaming plugins like twitch.tv, southpark.de and so on doesn't load a stream.
Regards
Greetings all
For owners of TBS Matrix device based on imx6 Openelec succesfully ported.
In 1 or 2 days will have it published on TBS forum.
Regards
i just tested the last few months different xbmc/kodi distros...and i have to say:
on both devices: cubox-i (i4pro) and hummingboard (i2ex) openelec runs great...!
Congratulations to all working XBMC/Kodi i.MX6 support for Linux on having pull request merged which among other things brings initial VPU decoding!
https://github.com/xbmc/xbmc/pull/5202
Do you think this mean that Kodi for Android will also get hardware assisted video decoding on Freescale i.MX 6 SoC series soon on Android too?
(2014-10-07, 01:22)wolfgar Wrote: [ -> ]Hi Hedda
Yes it should follow, I know Rabeeh already initiated this work (based on the same source) :
http://www.solid-run.com/community/topic...tml#p10838
Stéphan
Hi Stéphan,
Looks like Rabeeh have only posted links to XBMC/Kodi binaries on Dropbox there without posting source code on GitHub or as a separate package.
https://github.com/rabeeh/
Any chance you can contact him about submitting patches to upstream? or at least work the code somewhat publicly on his GitHub account?
Sure hope that this initial VPU code for Android too is contributed as a patch for upstream, and preferably in time for inclusion into Kodi 14 (Helix)!
Hi Hedda,
I think Rabeeh has compiled the same source we have made available for linux regarding VPU but I will ping him for confirmation...
Keep you informed
Stéphan
This might not be the right place to ask, but I'm trying to build this using the archlinuxarm PKGBUILD and it seems that OpenMax doesn't compile right. It's using the 3.10.17_1.0.0 vivante drivers. I cannot figure out why there are subtle differences in the symbol definitions:
Quote:OpenMaxVideo.cpp:59:33: error: ‘void* (* eglCreateImageKHR)(EGLDisplay, EGLContext, EGLenum, EGLClientBuffer, const EGLint*)’ redeclared as different kind of symbol
static PFNEGLCREATEIMAGEKHRPROC eglCreateImageKHR;
In file included from /opt/fsl/include/EGL/egl.h:327:0,
from /mnt/data/Builds/makepkg/xbmc-imx-git/src/xbmc-imx-git/xbmc/windowing/egl/WinSystemEGL.h:28,
from /mnt/data/Builds/makepkg/xbmc-imx-git/src/xbmc-imx-git/xbmc/windowing/WindowingFactory.h:39,
from OpenMaxVideo.cpp:31:
/opt/fsl/include/EGL/eglext.h:86:14: error: previous declaration of ‘void* eglCreateImageKHR(EGLDisplay, EGLContext, EGLenum, EGLClientBuffer, const EGLint*)’
EGLAPI EGLImageKHR EGLAPIENTRY eglCreateImageKHR (EGLDisplay dpy, EGLContext ctx, EGLenum target, EGLClientBuffer buffer, const EGLint *attrib_list);
OpenMaxVideo.cpp:60:34: error: ‘EGLBoolean (* eglDestroyImageKHR)(EGLDisplay, EGLImageKHR)’ redeclared as different kind of symbol
static PFNEGLDESTROYIMAGEKHRPROC eglDestroyImageKHR;
/opt/fsl/include/EGL/eglext.h:87:13: error: previous declaration of ‘EGLBoolean eglDestroyImageKHR(EGLDisplay, EGLImageKHR)’
EGLAPI EGLBoolean EGLAPIENTRY eglDestroyImageKHR (EGLDisplay dpy, EGLImageKHR image);
OpenMaxVideo.cpp:80:30: error: invalid use of incomplete type ‘class COpenMaxVideo’
COpenMaxVideo::COpenMaxVideo()
In file included from OpenMaxVideo.cpp:32:0:
DVDVideoCodec.h:49:7: error: forward declaration of ‘class COpenMaxVideo’
class COpenMaxVideo;
OpenMaxVideo.cpp:100:31: error: invalid use of incomplete type ‘class COpenMaxVideo’
COpenMaxVideo::~COpenMaxVideo()
