Full Version: Strange issues after driver update
Postet this in the windows support forum as well, but i figured that it could be at Metropolis issue, so here goes:
Yesterday i upgraded my Intel HD graphics drivers and everything looks fine in windows,.but my xbmc skin (metropolis) looks strange after the update, for example in xbmc settings the checkboxes at just scrambled images. and other places there are some odd graphics artifacts. It is a bit hard to describe it better.
If I change the skin to confluence or something other there are no problems - I even tried to delete the Metropolis skin and reeinstall it - But it still looks odd.
looks like some sort of overlay/transparency error
Sorry for the large pictures, they show the issues.
You probably will want to downgrade your driver then, as obviously XBMC has issues with it.
I can't think of any reason that the skin itself would be the culprit here, though.
Downgraded the drivers and everything works
Just out of curiousity, what OS are you on and what drivers did you experience this with ?
