Full Version: Media Portal -TV tuner
Newbe here with an initial start up issue . . . It appears that no channels loaded during config.
I am using OTA (Over the air antennas) with a Lenovo Q190 and a HD Homerun tuner (dual) thru my ATTUverse Router.
Not sure where I went wrong OR if the OTA will work on XBMC ...
Any assistance would be appreciated.
Thanks,
napamac
You need to explain yourself a little better. Live TV works with the latest version of XBMC. So do you have any channel's in the TV Server config tool?
have you configured the mediaportal server yet? can you provide any kind of details to how it's configured? programs versions help as well, there's 2/3 steps to getting xbmc to connect to media portal as you need mediaportal to handle the tv, then the xbmctvserver plugin, then xbmc plus the media portal pvr plugin enabled which you are prompted to do upon enabling live tv
on the assumption the applications are connecting to each other, when you scanned your channels, did you make sure to add them to your channels list?
