2013-04-10, 01:12
2013-04-10, 06:42
Are you referring to the "Edit smart playlist" window that is invoked when you select the "New smart playlist..." option? Or are you talking about something else? If it's the former, then this is the GUI used to create a smart playlist so you don't have to manually create/edit a smart playlist file. If it's the latter, then please provide more details about what you're referring to.
2013-04-10, 09:40
2013-04-10, 09:42
That's something skin-specific. I believe it's for configuring shortcuts to smartplaylists on the homepage. You could ask more in the appropriate skin forum.
2013-04-10, 10:05
OK, thanks, I wil ask there.
