2013-04-10, 10:48
Hi there, apologies if this isn't strictly the right place, but hopefully you'll be able to point me in the right direction.
I've just built my new HTPC;
MSI Z77IA-E53 m-itx board
Intel i3 3220
4GB DDR3 1600 RAM
128GB Sandisk mSata drive (mounted directly onto the board)
XBMCBunutu 12.0
I've got it all hooked up to my amp & TV over HDMI, just like the ones it's replacing.
Now, installation went fine, all done over HDMI. But now, when I boot, I get the XBMC splash screen - but after that the screen goes blank. If I stick the VGA cable in, it displays fine - but not ovr HDMI post the splash screen.
My own guess was down to display drivers, but I don't believe there's separate driver available. I thought maybe I'd changed a BIOS setting I shouldn't have, but I've reset them all to default with no effect.
thanks for any suggestions
Intel i3 3220
4GB DDR3 1600 RAM
XBMCBunutu 12.0
