Full Version: Poster not showing in some views
Poster artwork and clear art is not showing in now playing or "Episode" view for some shows. I cannot yet work out a common factor between those that work and those that don't. For shows that don't work, the poster does still show in other some other views.
Has anyone seen this before or can someone recommend the best way to find the source of the issue?
I can upload screenshots if needed.
Any suggestions hugely appreciated.
Thanks in advance.
Bump!
you'll see in the first screenshot that there is no poster art on the left when using now playing menu
https://dl.dropboxusercontent.com/u/1134...G_0211.JPG
and second screen shot (for the same show) the poster art is present
https://dl.dropboxusercontent.com/u/1134...G_0212.jpg
i get the same thing with Family Guy season 9 and 10 . no poster art. all my other seasons show up just fine. but for some reason season 9 and 10 no poster art..
i even double check that i have the folder names correctly . still cant figure it out. hopefully some one helps us out.
OK, think I have fixed it.
It looked to be due to the fact I had imported my library a month or so back. (Needed to reinstall XBMC).
All old episodes had the issue, newly added ones (since the import) were ok. I did a refresh and all appears to have come good. Happy days.
