Full Version: [Mod] Pointer Colors
Hello, this is something I made for myself so that my pointer matched the color I set Aeon Nox to, it adds color diffuse to your pointer. I kinda like it,
Screenshots with purple being used as main color, sorry about the double cursor, but XBMC doesnt capture the cursor in screenshots and the program I used to show cursor shows the small white arrow, but you get the idea:
Screenie with pointer focus:
Without pointer focus:
You can try it out and see if it looks right with the color you use. I included a backup folder to restore the original files if you dont like how it looks, so it wont hurt to test it out and see if you like it.
EDIT: For use with git version only ATM but I could make a theme for it but you could probably just use the pointer.xml and it will still work with existing cursors
I like it, nice idea as always.
