2013-04-12, 01:40
Hi, I have encountered a problem after activating profiles.
I have created an additional user (for my kids) both with and without profile lock, however anytime I log in via the kids profile it asks me for the master unlock code. I can press the escape key around 6 or 7 times and it will then log in and be functional to the relevant lock settings.
As the "kids" profile requires certain locked settings I am forced to use the master lock within my own profile.
The initial xbmc build was the current latest, however having looked to see if this has already been reported (and finding a similar issue that was dealt with in the bug tracker) I upgraded to nightly and unstable to test with the same result.
I have attempted to delete user profiles and re-initiate, I have also removed my advanced settings file which initially pointed to a central database and am using the original database.
My O/S is Ubuntu 12.04 64bit
here is a link to pastebin with a log level 2 from bootup to kids home screen (after esc many times)
http://pastebin.com/zGAEusqQ
Thanks in advance
Thanks in advance
