(2014-10-26, 02:26)Pienoet Wrote: [ -> ] (2014-10-01, 00:20)xbmclinuxuser Wrote: [ -> ]I'm mystified. Under version HTS Tvheadend 3.9.1553~g6a86c96~wheezy neither version of this addon seems to work. I can get the index.html page to appear, and if I click on Mobile UI that comes up, but if I click Timeline I just get a blank white page, and if I click Listings I see a grid with times on the left hand side but there is nothing in the grid.
I obtained the program by going to https://github.com/polini/TvheadendMobileUI and downloading the zip file, then (as root) copying the mobile directory from the zip file to /usr/share/tvheadend/src/webui/static/mobile. I assume I did it right since the index page comes up, but it simply appears that it isn't able to fetch any data from TVHeadEnd. I also tried the version at https://github.com/polini/TvheadendMobil...eadend-4.0 and it behaved exactly the same way.
Which version of the addon should I be using with HTS Tvheadend 3.9.1553~g6a86c96~wheezy, and how do I get it to work? Are there any dependencies or anything that need to be installed?
Also, are there any similar addons designed to bring a grid view (similar to what you see in XBMC) to the desktop web-based UI?
Same here i'm running Tvheadend 3.9.1780
Same here. Any updates to this project? It's really great, not only for mobile devices!
OK, I'm using tvheadend 3.9.2171.
I did a
git clone https://github.com/polini/TvheadendMobileUI.git
and a
git checkout tvheadend-4.0
to get the 4.0 branch.
But I only get
1 Unknown returncode
Any ideas?
(2014-11-29, 17:53)okoetter Wrote: [ -> ]Any ideas?
Sure… read the last few posts.
(2014-11-30, 15:41)Cassiel Wrote: [ -> ] (2014-11-29, 17:53)okoetter Wrote: [ -> ]Any ideas?
Sorry, But I don't find your comment very helpful.
I read the previous posts and they claim that they downloaded the zip file from Github while I cloned the whole repo.
I did think you cannot download a special branch in a zip file but always the master. But I rechecked and was wrong here. So sorry, my post was made too early.
(2014-11-30, 17:05)okoetter Wrote: [ -> ]Sorry, But I don't find your comment very helpful.
My previous posts clearly indicate that TvheadendMobileUi is outdated and won't work on recent versions of Tvheadend. I also recommended to use native iOS/Android apps instead as they offer more functionality and work as they should.
Perhaps.
However, for users PC project is great.
I hope I live to see the update.
Hello,
the code is now updated to the new API for current Tvheadend versions!
Please use the branch tvheadend-4.0 as indicated above.
Please be careful, as the version isn't tested well.
