2013-04-12, 21:47
I have a strange problem with a Acer RL80.
Have installed Ubuntu 12.10 with a patched Kernel (3.9.0-rc6) to resolve the bug that exists with kernel i915 driver.
Have installed XBMC from Team-XBMC repo along with X Edgers and their xserver/xorg and intel drivers, etc.
System boots fine, I can login and issue command startx...
VAinfo output
glxinfo output
If I run startx and then run xbmc from the command line - the whole system locks up and becomes unresponsive
however......
if I run startx and then run mplayer -vo vaapi film.mp4 everything works - film starts playing fine...
I can then watch the film, or press 'q' and exit from mplayer. I can then start xbmc and everything starts fine and works normally.
SO
xbmc will only work if I run mplayer beforehand and step through things manually. If I autostart (autologin to xbmc) it hangs, if i login manually, startx, then xbmc it hangs. If I login, startx, mplayer then xbmc it works......
anyone have any ideas?
VAinfo output
Quote:libva info: VA-API version 0.33.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_33
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.33 (libva 1.1.0)
vainfo: Driver version: Intel i965 driver - 1.0.19
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264Baseline : VAEntrypointVLD
VAProfileH264Baseline : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
glxinfo output
Quote:display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel® Sandybridge Mobile
OpenGL version string: 3.0 Mesa 9.1.1
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
however......
Quote:libavformat version 54.25.104 (internal)
libavformat file format detected.
[lavf] stream 0: video (h264), -vid 0
[lavf] stream 1: audio (aac), -aid 0, -alang und
VIDEO: [H264] 800x340 24bpp 23.976 fps 666.7 kbps (81.4 kbyte/s)
Clip info:
major_brand: isom
minor_version: 512
compatible_brands: isomiso2avc1mp41
encoder: Lavf54.61.104
Load subtitles in /home/xbmc/
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 54.54.100 (internal)
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, s16le, 127.9 kbit/8.33% (ratio: 15993->192000)
Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
[VD_FFMPEG] Trying pixfmt=1.
Movie-Aspect is 2.35:1 - prescaling to correct movie aspect.
VO: [vaapi] 800x340 => 800x340 H.264 VA-API Acceleration
SO
