2013-04-15, 16:28
2013-04-15, 16:40
Launching high bitrate files is a little quicker with GbE. 100 Mbps just isn't much when you're talking about maybe 80-85 Mbps after overhead. GbE lets you fill the buffer up in no time in comparison.
2013-04-15, 17:45
(2013-04-15, 16:40)DrChips Wrote: [ -> ]Launching high bitrate files is a little quicker with GbE. 100 Mbps just isn't much when you're talking about maybe 80-85 Mbps after overhead. GbE lets you fill the buffer up in no time in comparison.
You got the point.
Also I do love to have real fast transfers between my devices. [60 MB/s or up.] I am planning to buy 2 Brix [ IF the Celeron versions have GbE and USB 3.0], one for storage [+ 2x 4HDD case w/ usb3] and other to replace my RasPi [He does the job, but doesnt have storage].
2013-04-15, 19:31
(2013-04-15, 11:28)eskro Wrote: [ -> ]only the price tag will tell if it'll win or loose.
Totally agree!
I try not to get too excited about these new products after Microsoft's debacle with Surface.
I have yet to see someone with a Microsoft Surface AND for good reason,......too much $$$$$$$$.
If this Brix doesn't sell for a competitive price (meaning ~$100-$200), but instead sells it for 5X that amount,...it'll be a dud.
2013-04-29, 23:55
Anyone seen any prices or release dates for this yet?
2013-04-30, 09:06
Just been told by gigabyte that they are launching them in June. Hmmm, might just get the nuc in that case.
2013-04-30, 10:36
(2013-04-30, 09:06)churchwa Wrote: [ -> ]Just been told by gigabyte that they are launching them in June. Hmmm, might just get the nuc in that case.
Not that long to wait though now though really. Did they give any indication of pricing?
2013-04-30, 13:11
(2013-04-15, 19:31)GortWillSaveUs Wrote: [ -> ]If this Brix doesn't sell for a competitive price (meaning ~$100-$200), but instead sells it for 5X that amount,...it'll be a dud.
Very unlikely don't you think. The Core i3-3227U one of the 4 cpu's used in the Brix alone costs 225 $
And Gigabyte will not sell with a loss, no company would. Prices will probably be in the neighborhood of the Intel NUC or even a bit higher.
2013-05-12, 22:11
2013-05-13, 02:37
(2013-05-12, 22:11)colonelblighty Wrote: [ -> ]Specs etc added to Gigabyte site now.
http://uk.gigabyte.com/products/list.aspx?s=47&ck=104
The only thing the specs say are different from the three versions seems to be the CPU. Also all the mention for GPU is " Intel Graphics". Hopefully they release more info on the GPU...
2013-05-13, 03:50
Seems a little dumb to release this now with haswell just around the corner.
2013-05-13, 08:18
(2013-05-13, 02:37)BORIStheBLADE Wrote: [ -> ](2013-05-12, 22:11)colonelblighty Wrote: [ -> ]Specs etc added to Gigabyte site now.
HD4000 if it is this i3 chip in the base model
http://ark.intel.com/m/products/72057/In...e-1_90-GHz
No mention of a celeron version though that thy originally announced.
2013-05-13, 09:37
(2013-05-13, 03:50)touser Wrote: [ -> ]Seems a little dumb to release this now with haswell just around the corner.
Haswell is more than one CPU SKU, and if history is anything to go by they won't all launch at the same time. How far away are the Haswell equivalents of the mobile parts used in these units? It could be many months.
2013-05-13, 15:36
(2013-05-13, 08:18)colonelblighty Wrote: [ -> ](2013-05-13, 02:37)BORIStheBLADE Wrote: [ -> ](2013-05-12, 22:11)colonelblighty Wrote: [ -> ]Specs etc added to Gigabyte site now.
Thanks for the info!
2013-05-13, 16:02
BRIX Models.
BRIX GB-XM12-3227
CPU: Intel® Core™ i3-3227U 1.9GHz
# OF CORES......................................2
# OF THREADS..................................4
CLOCK SPEED...................................1.9 GHz
CACHE................................................3 MB
SYSTEM BUS......................................5 GT/s
INSTRUCTION SET.............................64-bit
INSTRUCTION SET EXTENSIONS.......AVX
EMBEDDED OPTIONS AVAILABLE.....No
LITHOGRAPHY...................................22 nm
MAX TDP............................................17 W
GPU:...................................................Intel® HD Graphics 4000
GRAPHICS MAX DYNAMIC FREQUENCY = 1.1 GHz
Source Link
_
BRIX GB-XM11-3337
CPU: Intel® Core™ i5-3337U 1.8GHz / 2.7GHz
# OF CORES.....................................2
# OF THREADS.................................4
CLOCK SPEED..................................1.8 GHz
MAX TURBO FREQUENCY................2.7 GHz
CACHE...............................................3 MB
SYSTEM BUS.....................................5 GT/s
INSTRUCTION SET............................64-bit
INSTRUCTION SET EXTENSIONS......AVX
EMBEDDED OPTIONS AVAILABLE....No
Source Link
_
BRIX GB-XM1-3537
CPU: Intel® Core™ i7-3537U 2GHz / 3.1GHz
CLOCK SPEED..................................2 GHz
MAX TURBO FREQUENCY................3.1 GHz
CACHE..............................................4 MB
INSTRUCTION SET EXTENSIONS.....AVX
LITHOGRAPHY..................................22 nm
MAX TDP...........................................17 W
GRAPHICS MAX DYNAMIC FREQUENCY = 1.2 GHz
Source Link
BRIX GB-XM12-3227
Source Link
_
BRIX GB-XM11-3337
Source Link
_
BRIX GB-XM1-3537
Source Link
