I found out after looking at both my log and your log, it's a bug in SportsDevil where it's using the wrong server for ilive.to.
It's trying live.ilive.to vs live2.ilive.to.
I will mention this to the SportsDevil folks.
thank you.. cause it does the same thing for superusvoxtv or most in custom modules...
but thanks for your response
(2013-04-14, 04:16)jahruze23 Wrote: [ -> ]that doesnt work either
You can just try using my list in LiveStreams to watch many of the ilive.to channels already.
Reorganized the Mediafire folder a tad by removing long folder names so it's a lot easier to read even for desktop users but hopefully a lot better for mobile users.
Hi Redpenguin,
you could make a new one updated .APK with the library but with a stable version of XBMC?
such as 12 or 12.1?
Is that with that 13 Gotham Alpha 2 emissions have noticed that online take much and put in pause mode.
np, that was actually on my to-do list as I figured not everybody would be comfortable running experimental code.
Even though in a way my APKs are experimental LoL.
EDIT: APK uploaded and should work fine
. Not sure what happens if you try to install it over 13.0 Alpha 2 though. Never tested but not having an Android product myself hard to test, I started making them for my buddy's Android.
Hey RedPenguin
Any idea about a Librtmp for the atv1. Every single time i would find one it and try it, it would cause a an error 13 in xbmc.
(2013-04-15, 15:30)crusader88 Wrote: [ -> ]Hey RedPenguin
Are you using the one for RasPi while running Linux? Another user said the iOS one will not work on default ATV1 install.
(2013-04-15, 22:27)RedPenguin Wrote: [ -> ] (2013-04-15, 15:30)crusader88 Wrote: [ -> ]Hey RedPenguin
I am running an apple tv with crystalbuntu. Its linux, i have never tried running an librtmp on that, but i have on a stock ios 3.0.2 atv1 and they never work. I never tried the one for linux on an atv1. The files wont match as i believe the linux one runs on .so and the normail on is .dll i think.
(2013-04-15, 22:45)crusader88 Wrote: [ -> ] (2013-04-15, 22:27)RedPenguin Wrote: [ -> ] (2013-04-15, 15:30)crusader88 Wrote: [ -> ]Hey RedPenguin
Yes you do need .so for Linux, which is why I said try the RasPi version from my MediaFire, as I have had one other ATV1 user claim it definitely works on Linux with the ATV1, because it's simply compiled for Linux ARM which both the RasPi and ATV1 are.
(2013-04-15, 23:33)RedPenguin Wrote: [ -> ] (2013-04-15, 22:45)crusader88 Wrote: [ -> ] (2013-04-15, 22:27)RedPenguin Wrote: [ -> ]Are you using the one for RasPi while running Linux? Another user said the iOS one will not work on default ATV1 install.
Ok i will try it and tell you what happens.
