2013-10-16, 22:06
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101
2013-10-17, 06:53
I tried a couple linux builds but have so many issues with them. 1. It tells me file system is readonly and i can't update limrtmp file
2. If a channel says working trying to load and I stop it then it freezes and i have to reboot
3. I'm lost
4. Still $100 to whoever gets librtmp.so to stick on reboot in Android
5. Thanks
Is there a custom android install anywhere for this?
3. I'm lost
5. Thanks
2013-10-18, 12:31
Hi all,
first of all, thank you for the job you are doing!
I am new here, and I installed for the first time xbmc this morning, just because I wanted to see HULU on my android devices. I have already mod the flash player, but it is lil buggy, so I was looking for something more stable!
Well I first installed the stable version for android, installed, installed the rep fusion, installed the addon hulu, and watched a lot of ads!
So, I found out there was a procedure to avoid the loop of ads, I did it but now every time I try to see a video on HULU, I can just see: "HULU" screen for 2 secs and then back to main menu
I found out that maybe I would need a new version of what you call librtmp, so finally, I reached the mediafire folder of Redpenguin. I tried to copy the file librtmp.so in my android folder, but as someone already said, I got no connection to internet. I tried to download the version of pajopasa, i signed it installed but as soon as i get in the main menu of the app, it crashes!
I tried to copy the librtmp.so from his version to the stable froyo and then after signed it up i installed getting the same crash! So i think the problem would be that file.
So, this is what I got so far, spending lot of hours around forums My question now would be: am I missing something? Because I cannot find any other info around, so it looks like either the problem has been solved and I am still missing "that webpage", or everything been abandoned?
Ah! I tried some nightly version, but I have all addon "bronken"
Ok I hope someone could help me to understand the situation. Thank you
2013-10-18, 12:49
I have two questions:
- Why is the latest librtmp not included in the Gotham Alpha and Nightly builds?
- Since the problem on Android seems to be that the new librtmp is replaced by the old one after reboot, would it be possible that we run a script at startup that updates the librtmp again?
2013-10-19, 15:30
Ok, I was able to run HULU with the September monthly version of XMBC... if anyone is interested..
However, I am still curious if there is any news about the stable one... 'cause some addons don't work this with version
Thank you
Thank you
2013-10-20, 17:34
(2013-10-13, 20:12)RedPenguin Wrote: [ -> ](2013-10-13, 05:15)raub Wrote: [ -> ]Thank you for taking the time to look at my log. The plugin name is shahid MBC. I was told my libertmp is outadated. I updated using yours but the videos still dont play. The videos are on demand not live streams.
Still looking into this issue.
(2013-10-13, 17:37)wqwert Wrote: [ -> ]Could you please someone tell me, how to update librtmp on j1nx xbmc buildroot device (g-box midnight)?
Thanks you.
Android 4.3?
If so I am currently working on a new Android toolchain, to try and see if that's what's crashing Android's XBMC for everybody.
I believe it's a 4.3 issue because even the librtmp files that folks had no issues with in the past now crash on Android.
Thank you for the reply. Buy I'm running j1nx build root Linux version. Can you guide me to update the lib rtmp on it?. Thanks.
2013-10-28, 22:38
[/quote]
[/quote]
same here.. i am using linux build on my g box and donĀ“t know how to update and which file to use to librtmp update,.
[/quote]
2013-10-30, 01:17
Hi, I recently bought a pipo m7 android pad, and noticed I need to fix the librtmp issue on this one too, but there's no lib folder in the org.xbmc.xbmc folder. This is really strange. Anyone have a clue? I use the latest nightly version which works excellent and the apk version in this link doesn't work on the Internet.
2013-10-31, 22:29
A short update...
I had to root the pad, and use root explorer to find the correct folder, which I managed to fix. However, replacing the librtmp.so doesn't work still. I'm not really sure where to find the correct android version in the file structure im mediafire. The latest I found is from09-24-13, but using it still doesn't work in XOT-uzg, which i hope is allowed to talk about according to xbmc rules.
2013-11-05, 16:47
nevermind... now it's working again
just buffering A LOT!!!
i don't know what's going on... just very sporadic.
gonna leave this open -- http://pastebin.com/3QjngVti
'cause it will play for a few seconds, and then this error shows back up again.
and.... it's working again... for the moment.
09:33:21 T:140246534518528 NOTICE: Thread DVDPlayer start, auto delete: false
09:33:21 T:140246534518528 NOTICE: Creating InputStream
09:33:51 T:140246534518528 ERROR: RTMP_Connect1, handshake failed.
09:33:51 T:140246534518528 ERROR: CDVDPlayer::OpenInputStream - error opening
2013-11-05, 17:01
Where can I download the libRTMP for android? will it work with all versions?
Mine -> 4.0.4
XBMC - 12.2 Git 20130513 on Samsung Galaxy Tablet 10.1 - GT-P7500
Mine -> 4.0.4
2013-11-05, 22:03
2013-11-07, 01:37
I have got a funny problem after updating to new librtrmp to this one http://www.mediafire.com/?x4cvp5hl4m9xr#8t53ue83187x3 or using the librtemp.so from any of the redpenguin apk , in my mediabox it is a generic generic amlogic 8726-mx with 1gb ram and 8 gb rom. Some channels on livetv addon (or livestreams ) not working , which are normally working with the factory installed xbmc or this rom http://forum.androidgadget.co.uk/showthread.php?tid=300 . the log file is http://xbmclogs.com/show.php?id=81089 . the channels i am trying to access are <item>
<title>Reporter</title>
<link>rtmp://cdn.nwk3.yupptv.tv/nwk3 playpath=reporter swfUrl=http://cdn.freedocast.com/player-octo/yume/v5/infinite-hd-player-YUPPTV.SWF live=true timeout=15 pageUrl=http://www.yupptv.com/streams/reporter.aspx</link>
<thumbnail>http://www.turbotv.in/wp-content/uploads/2012/10/Reporter-TV-Channel.jpg</thumbnail>
</item>
<item>
<title>Indiavision</title>
<link>rtmp://live.wmncdn.net/indiavisiontv/ playpath=db65322988fe2be4bc40b7175de75c0e.sdp swfUrl=http://player-emea-uk.webmobilive.com/player/liveplayer.swf pageUrl=http://live.indiavisiontv.com/
timeout=15</link>
<thumbnail>http://upload.wikimedia.org/wikipedia/en/2/25/Indiavision.gif</thumbnail>
</item>
<item>
<title>AsiaNet News</title>
<link>rtmp://cdn.m.yuppcdn.net:80/liveorigin playpath=asianet2 swfUrl=http://cdn.freedocast.com/player-octo/yume/v5/infinite-hd-player-YUPPTV.SWF live=true timeout=15 pageUrl=http://www.yupptv.com/streams/asianetnews.aspx</link>
<thumbnail>http://www.livemalayalam.com/wp-content/themes/MagFolio/thumb.php?src=http://www.livemalayalam.com/img/icon/asianet.jpg&w=500&zc=1&q=80&bid=1</thumbnail>
</item>
Please someone help
thanks in advance
</item>
<item>
timeout=15</link>
</item>
<item>
</item>
Please someone help
thanks in advance
2013-11-09, 01:42
Hi!
In the mediafire folder there is no osx version available for the latest KSV release.
I've been tryin to compile it myself but need librtmp to be 32bit and I can't figure out how to do that on my 64bit mac?
Thanks for any help!
EDIT Finally managed to compile a working version using:
make SYS=darwin CFLAGS='-arch i386' LDFLAGS='-arch i386'
2013-11-09, 20:37
Please any Linux experts help me I got putty installed in my pc and it is showing the
[root@amlogic /root]# find / | grep librtmp.so.0
/usr/lib/librtmp.so.0
and the latest file on C:\Users\All Users.AllUsers-PC\Desktop\librtemp folder , how can I transfer it to my box
Thanks in advance
aby
Thanks in advance
aby
