2014-09-03, 20:55
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101
2014-09-03, 21:45
patria o muerte, I already provided you a SPMC APK with an updated librtmp. Why are u requesting again? it didn't work?
I'm not making modded APKs without launchers or whatever. But the link i gave u have the latest Librtmp included.
Thats the purpose of this topic. Not removing modules.
2014-09-03, 21:55
Hi, here it is. Sorry for the delay:
libssl.so.1.0.0 => /usr/lib/arm-linux-gnueabihf/libssl.so.1.0.0 (0xb6ea5000)
libcrypto.so.1.0.0 => /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0 (0xb6d42000)
libz.so.1 => /lib/arm-linux-gnueabihf/libz.so.1 (0xb6d24000)
libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0xb6cb3000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0xb6b83000)
libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0xb6b77000)
/lib/ld-linux-armhf.so.3 (0xb6f22000)
libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0xb6b4f000)
2014-09-03, 22:02
It still makes no sense. According to those outputs you provided, both my file and the original are linked to the exact same libraries. So no reason at all my library should cause any issue at all.
Try running the following command:
ls -lh /opt/xbmc-bcm/xbmc-bin/lib/xbmc/system
And if you would please put the output in between ["code"] ["/code"] so that it's easier to read via the forum. (Without the quotes ("), had to do that for the forum to show you the tags).
Also if anyone else is having issues please post this same output
Mabs if you see this can you also please post if you don't mind, since yours is working great?
2014-09-03, 22:09
Do you want my output with 30.08 or the today version (126Kb)?
If u think it helps, I can also send you my log
2014-09-03, 22:10
(2014-09-03, 22:09)Mabs Wrote: [ -> ]Do you want my output with 30.08 or the today version (126Kb)?
I would say today's version prob would make more sense, though technically either should work and produce the same results.
2014-09-03, 22:12
@RedPenguin, here are the results for OpenELEC on R-Pi (Helix master, build #0902):
With the 1.8MB test build from post #943:
This librtmp test build is working in OpenELEC.
And your updated test build from post #951:
This librtmp test build is not working - it is missing libssl (and also libcrypto):
The dynamic linking of these libraries (presumably, they are statically linked in the working version?) explains why the non-working version is so much smaller.
These are the missing libraries as they are installed on OpenELEC:
Adding symbolic links for the installed versions of the libraries...
also doesn't work as the shared object library /usr/lib/libssl.so.27.0.0 is actually based on the LibreSSL fork of OpenSSL, so the installed libssl library is missing various expected properties:
So for librtmp to work on OpenELEC (Helix) it needs to be statically linked with libssl (OpenSSL version) and libcrypto, or a version created that dynamically links against libcrypto and the LibreSSL fork of libssl (I believe OpenELEC Gotham is still based on OpenSSL).
Ideally a single version of librtmp would work with whatever version of libcrypto or libssl is installed on the system (whether LibreSSL or OpenSSL, 1.0 or 27.0.0 etc.), assuming this is even possible... maybe some library load magic...?
rpi512:~ # ls -la ./freenas/data/librtmp_test1.so.0
-rw-rw-r-- 1 1001 1001 1865435 Sep 3 19:57 ./freenas/data/librtmp_test1.so.0
rpi512:~ # ldd ./freenas/data/librtmp_test1.so.0 | sort
/lib/ld-linux-armhf.so.3 (0xb6fc2000)
/lib/libarmmem.so (0xb6e2e000)
libc.so.6 => /lib/libc.so.6 (0xb6c79000)
libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0xb6c54000)
libm.so.6 => /lib/libm.so.6 (0xb6da9000)
libz.so.1 => /usr/lib/libz.so.1 (0xb6e1c000)
rpi512:~ # ls -la ./freenas/data/librtmp_test2.so.0
-rw-rw-r-- 1 1001 1001 128388 Sep 3 20:33 ./freenas/data/librtmp_test2.so.0
rpi512:~ # ldd ./freenas/data/librtmp_test2.so.0 | sort
/lib/ld-linux-armhf.so.3 (0xb6ee8000)
/lib/libarmmem.so (0xb6eb8000)
libc.so.6 => /lib/libc.so.6 (0xb6d03000)
libcrypto.so.1.0.0 => not found
libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0xb6cdd000)
libm.so.6 => /lib/libm.so.6 (0xb6e33000)
libssl.so.1.0.0 => not found
libz.so.1 => /usr/lib/libz.so.1 (0xb6ea6000)
20:36:56 52185.804688 T:2764440656 DEBUG: SECTION:LoadDLL(librtmp.so.0)
20:36:56 52185.812500 T:2764440656 DEBUG: Loading: librtmp.so.0
20:36:56 52185.816406 T:2764440656 ERROR: Unable to load librtmp.so.0, reason: libssl.so.1.0.0: cannot open shared object file: No such file or directory
20:36:56 52185.816406 T:2764440656 DEBUG: Dll librtmp.so.0 was not found in path
rpi512:~ # ls -la `find /usr/lib -name 'libcrypto*' -or -name 'libssl*'`
lrwxrwxrwx 1 root root 19 Sep 2 21:57 /usr/lib/libcrypto.so -> libcrypto.so.30.0.0
lrwxrwxrwx 1 root root 19 Sep 2 21:57 /usr/lib/libcrypto.so.30 -> libcrypto.so.30.0.0
-rwxr-xr-x 1 root root 1270692 Sep 2 21:57 /usr/lib/libcrypto.so.30.0.0
lrwxrwxrwx 1 root root 16 Sep 2 21:57 /usr/lib/libssl.so -> libssl.so.27.0.0
lrwxrwxrwx 1 root root 16 Sep 2 21:57 /usr/lib/libssl.so.27 -> libssl.so.27.0.0
-rwxr-xr-x 1 root root 270944 Sep 2 21:57 /usr/lib/libssl.so.27.0.0
rpi512:~ # cd /var/tmp/libhack/3rdparty/
rpi512:~ # ln -s /usr/lib/libssl.so libssl.so.1.0.0
rpi512:~ # ln -s /usr/lib/libcrypto.so libcrypto.so.1.0.0
rpi512:~ # ls -la
lrwxrwxrwx 1 root root 21 Sep 3 21:01 libcrypto.so.1.0.0 -> /usr/lib/libcrypto.so
lrwxrwxrwx 1 root root 38 Sep 3 06:07 librtmp.so -> /var/tmp/libhack/3rdparty/librtmp.so.0
-rwxr-xr-x 1 root root 128388 Sep 3 20:56 librtmp.so.0
lrwxrwxrwx 1 root root 18 Sep 3 20:59 libssl.so.1.0.0 -> /usr/lib/libssl.so
21:01:52 53682.089844 T:2764440656 DEBUG: SECTION:LoadDLL(librtmp.so.0)
21:01:52 53682.113281 T:2764440656 DEBUG: Loading: librtmp.so.0
21:01:52 53682.113281 T:2764440656 ERROR: Unable to load librtmp.so.0, reason: /usr/lib/libssl.so.27: version `OPENSSL_1.0.0' not found (required by /var/tmp/libhack/3rdparty/librtmp.so.0)
21:01:52 53682.113281 T:2764440656 DEBUG: Dll librtmp.so.0 was not found in path
2014-09-03, 22:23
Thank you Milhouse, it's all starting to make some sense to me now.
I think it was just confusing at first as it seemed for ages the builds always worked and then randomly stopped working on RaspBMC out of no where.
2014-09-03, 22:30
If there is a way you can relax the property checks for "OPENSSL_1.0.0" (etc.) when the libssl.so.1.0.0 library is loaded, then it might be possible to use a common version of librtmp.so.0 (the small, 126KB version) on OpenELEC once the additional symbolic links to libcrypto.so and libssl.so are added to the "hack" directory. Note that I'm assuming the LibreSSL version of libssl.so is a drop-in replacement for the OpenSSL libssl.so, which may or may not be the case (I thought that was the initial objective).
2014-09-03, 22:40
RP, here is the output:
PLease note that you'll see your librtmp, and the "old_lbrtmp", which is the original file.
total 6.6M
-rwxr-xr-x 1 root root 614K Aug 19 05:08 ImageLib-arm.so
-rwxr-xr-x 1 root root 65K Aug 19 05:08 hdhomerun-arm.so
-rw-r--r-- 1 root root 196K Aug 19 05:09 libEGL.so
-rw-r--r-- 1 root root 255K Aug 19 05:09 libEGL_static.a
lrwxrwxrwx 1 root root 12 Aug 19 05:09 libGLESv1_CM.so -> libGLESv2.so
-rw-r--r-- 1 root root 104K Aug 19 05:09 libGLESv2.so
-rw-r--r-- 1 root root 106K Aug 19 05:09 libGLESv2_static.a
-rw-r--r-- 1 root root 96K Aug 19 05:09 libOpenVG.so
-rw-r--r-- 1 root root 77K Aug 19 05:09 libWFC.so
lrwxrwxrwx 1 root root 17 Aug 19 05:08 libafpclient.so -> libafpclient.so.0
lrwxrwxrwx 1 root root 21 Aug 19 05:08 libafpclient.so.0 -> libafpclient.so.0.0.0
-rw-r--r-- 1 root root 101K Aug 19 05:08 libafpclient.so.0.0.0
-rw-r--r-- 1 root root 101K Aug 19 05:09 libbcm_host.so
lrwxrwxrwx 1 root root 16 Aug 19 05:08 libbluray.so.1 -> libbluray.so.1.0
lrwxrwxrwx 1 root root 18 Aug 19 05:08 libbluray.so.1.0 -> libbluray.so.1.0.0
-rw-r--r-- 1 root root 158K Aug 19 05:08 libbluray.so.1.0.0
lrwxrwxrwx 1 root root 11 Aug 19 05:08 libcec.so -> libcec.so.2
lrwxrwxrwx 1 root root 15 Aug 19 05:08 libcec.so.2 -> libcec.so.2.0.1
-rw-r--r-- 1 root root 441K Aug 19 05:08 libcec.so.2.0.1
-rwxr-xr-x 1 root root 170K Aug 19 05:08 libcmyth-arm.so
-rwxr-xr-x 1 root root 84K Aug 19 05:08 libcpluff-arm.so
lrwxrwxrwx 1 root root 12 Aug 19 05:08 libcurl.so -> libcurl.so.3
lrwxrwxrwx 1 root root 12 Aug 19 05:08 libcurl.so.3 -> libcurl.so.4
lrwxrwxrwx 1 root root 16 Aug 19 05:08 libcurl.so.4 -> libcurl.so.4.2.0
-rw-r--r-- 1 root root 356K Aug 19 05:08 libcurl.so.4.2.0
-rw-r--r-- 1 root root 16K Aug 19 05:09 libdebug_sym.so
lrwxrwxrwx 1 root root 17 Aug 19 05:08 libdshairport.so -> libshairport.so.0
lrwxrwxrwx 1 root root 14 Aug 19 05:08 libdvdcss.so -> libdvdcss.so.2
lrwxrwxrwx 1 root root 18 Aug 19 05:08 libdvdcss.so.2 -> libdvdcss.so.2.1.0
-rw-r--r-- 1 root root 34K Aug 19 05:08 libdvdcss.so.2.1.0
-rwxr-xr-x 1 root root 28K Aug 19 05:08 libexif-arm.so
-rw-r--r-- 1 root root 14K Aug 19 05:09 libkhrn_client.a
-rw-r--r-- 1 root root 451K Aug 19 05:09 libkhrn_static.a
-rw-r--r-- 1 root root 13K Aug 19 05:09 libmmal.so
-rw-r--r-- 1 root root 70K Aug 19 05:09 libmmal_core.so
-rw-r--r-- 1 root root 73K Aug 19 05:09 libmmal_util.so
-rw-r--r-- 1 root root 44K Aug 19 05:09 libmmal_vc_client.so
lrwxrwxrwx 1 root root 17 Aug 19 05:08 libmp3lame.so.0 -> libmp3lame.so.0.0
lrwxrwxrwx 1 root root 19 Aug 19 05:08 libmp3lame.so.0.0 -> libmp3lame.so.0.0.0
-rw-r--r-- 1 root root 287K Aug 19 05:08 libmp3lame.so.0.0.0
lrwxrwxrwx 1 root root 11 Aug 19 05:08 libnfs.so -> libnfs.so.1
lrwxrwxrwx 1 root root 15 Aug 19 05:08 libnfs.so.1 -> libnfs.so.1.0.3
-rw-r--r-- 1 root root 111K Aug 19 05:08 libnfs.so.1.0.3
-rw-r--r-- 1 root root 32K Aug 19 05:09 libopenmaxil.so
lrwxrwxrwx 1 root root 12 Aug 19 05:08 librtmp.so -> librtmp.so.0
-rw-r--r-- 1 root root 126K Sep 3 17:07 librtmp.so.0
lrwxrwxrwx 1 root root 12 Sep 3 00:41 librtmp.so.1 -> librtmp.so.0
lrwxrwxrwx 1 root root 17 Aug 19 05:08 libshairplay.so -> libshairplay.so.0
lrwxrwxrwx 1 root root 21 Aug 19 05:08 libshairplay.so.0 -> libshairplay.so.0.0.0
-rw-r--r-- 1 root root 102K Aug 19 05:08 libshairplay.so.0.0.0
lrwxrwxrwx 1 root root 21 Aug 19 05:08 libshairport.so.0 -> libshairport.so.0.0.0
-rw-r--r-- 1 root root 46K Aug 19 05:08 libshairport.so.0.0.0
lrwxrwxrwx 1 root root 16 Aug 19 05:08 libssh2.so.1 -> libssh2.so.1.0.1
-rw-r--r-- 1 root root 128K Aug 19 05:08 libssh2.so.1.0.1
lrwxrwxrwx 1 root root 13 Aug 19 05:08 libtag.so.1 -> libtag.so.1.0
lrwxrwxrwx 1 root root 16 Aug 19 05:08 libtag.so.1.0 -> libtag.so.1.12.0
-rw-r--r-- 1 root root 1.4M Aug 19 05:08 libtag.so.1.12.0
-rw-r--r-- 1 root root 3.0K Aug 19 05:09 libvcfiled_check.a
-rw-r--r-- 1 root root 30K Aug 19 05:09 libvchiq_arm.so
-rw-r--r-- 1 root root 131K Aug 19 05:09 libvchostif.a
-rw-r--r-- 1 root root 27K Aug 19 05:09 libvcilcs.a
-rw-r--r-- 1 root root 162K Aug 19 05:09 libvcos.so
-rw-r--r-- 1 root root 21K Aug 19 05:09 libvcsm.so
-rw-r--r-- 1 root root 30K Aug 19 05:09 libvmcs_rpc_client.a
lrwxrwxrwx 1 root root 12 Aug 19 05:08 libxslt.so -> libxslt.so.1
lrwxrwxrwx 1 root root 17 Aug 19 05:08 libxslt.so.1 -> libxslt.so.1.1.26
-rw-r--r-- 1 root root 214K Aug 19 05:08 libxslt.so.1.1.26
-rw-r--r-- 1 root root 101K Aug 19 05:08 old_librtmp.so.0
drwxr-xr-x 4 root root 4.0K Aug 19 05:08 players
2014-09-03, 22:55
And mine:
root@raspbmc:~# ls -lh /opt/xbmc-bcm/xbmc-bin/lib/xbmc/system
total 6.5M
-rwxr-xr-x 1 root root 126K Sep 3 16:13 librtmp.so.0
lrwxrwxrwx 1 root root 12 Aug 31 18:41 librtmp.so.1 -> librtmp.so.0
2014-09-03, 23:06
Where are the libssl.so.* and libcrypto.so.* libraries in Raspbmc... presumably /usr/lib?
2014-09-03, 23:07
(2014-09-03, 23:06)Milhouse Wrote: [ -> ]Where are the libssl.so.* and libcrypto.so.* libraries in Raspbmc... presumably /usr/lib?
They are located in /usr/lib/arm-linux-gnueabihf/.
2014-09-04, 13:10
Any new idea, guys? Mine now is on a loop of reboots. Can't do anything but wait and hope to stop.
EDIT: Even during the reboot loop, I managed to root access using Filezilla, change RP's librtmp for the original one and it stopped immediately on the main menu.
Strange how I could do it while the Pi was rebooting and also strange the speed that it became stable right after the file change.
I feel bad for giving you all this trouble.
2014-09-04, 14:00
(2014-09-03, 21:45)Mabs Wrote: [ -> ]patria o muerte, I already provided you a SPMC APK with an updated librtmp. Why are u requesting again? it didn't work?
Hi Mabs,
thank you for provide me your apk,it works fine but i can't hide the systembar,it's very annoying.
