There is a more recent librtmp.dll for windows that you can try.
Go to mediafire link from RedPenguin and search for "10-3-14 Fixed ..." folder.
There is also an Android version inside that folder that you can try, but it isn't working for me and some other users. Please give feedback if you test that.
(2014-10-30, 16:54)Mabs Wrote: [ -> ]There is a more recent librtmp.dll for windows that you can try.
I tried the new librtmp on my windows xbmc but the channels didn't work
Sorry, in Android, I have to get the files from fixed tcommand&k or fixes? Thanks.
(2014-10-31, 21:21)Mabs Wrote: [ -> ]Fixed Tcom...
HI! @
RedPenguin & @
Mabs
After update IOS 8.1 librtmp old & new not working on my iphone 6+ & ipad .
Also Mini X8- H Android after framwire update nothing is working .
Any way i can fix it ??
PLA HELP
Jagobd.com on windows xbmc 13.2 has started working a day later after updating librtmp to the latest one. But can't figure out how to update it on my fire tv. I used the command
adb push librtmp.so /data/data/org.xbmc.xbmc/lib/librtmp.so
but keep on getting "permission denied" message even though my fire tv is rooted. I was able to upload it to the download folder but couldn't find any option in ES File Explorer to copy/paste it to the /data/data/org.xbmc.xbmc/lib/ folder. Any suggestions will be great. Thanks!
APK SPMC (13.3.3) with LibRTMP from 30.08.2014:
http://www.mediafire.com/?o10a306xuonx8d1
APK SPMC (13.3.3) (Launcher) with LibRTMP from 30.08.2014:
http://www.mediafire.com/?3negmlp70cn3l08
Sorry for flooding the topic with links, but just did this apks with the "new" SPMC files.
Just ignore or delete previous links from me for SPMC.
BIG THX to Koying, KSV and RedPenguin for sharing their work.
And of course, the entire Kodi Team !!!
Hi.
I have an MX Android box. I would like to have root access to update the librtmp file. How do I get this root access? Thanks
Hi! @ shani_08
After u update "jagoBD" yesterday nothing is working .
can u fix it pls.
But in Sportsdevil (jagoBD) working fine.
Mabs
Is this update gonna play the new trick of Janjua.tv mips.tv ucaster etc?
If so anyone confirmed of working on Android Gotham?
Help is appreciated.
(2014-11-02, 18:02)Mabs Wrote: [ -> ]APK SPMC (13.3.3) with LibRTMP from 30.08.2014:
https://www.mediafire.com/?k8rdiczdz9jd7df
(2014-11-04, 14:15)shawonmq Wrote: [ -> ]@Mabs
I'm only changing ONE file inside the APK. I'm not the author of the librtmp patches and certainly not deserve any credits.
KSV and RedPenguin are the one's that can answer your questions. They do the "hard work"
I'm using the librtmp file from 30.08.2014 that is the lastest version working.
There is new patches from KSV that MAY solve that "new trick" from those sites. But there is no file yet to be used.
Please help!
I don't know how to update a file from Android TV box. I do from Windows like Program File/xbmc/system and so on
For Android: data/data/org.xbmc.xbmc/lib/librtmp.so.
I don't think I do this within xbmc. If I go to xbmc setting/addon/install from zip file/root..... and I see data/data and then blank, or go to android/org.xbmc.xbmc/files then blank. The files are hidden. I have read several posts, some said update from the Maintenance Tool.
(2014-11-07, 17:08)Thapr14 Wrote: [ -> ]Please help!
u have to root ur device then u can go....
