An idea just dawned on me. librtmp.dll is the same on all platforms, correct? If so, I can just do the easy update on my PC and then share it through Dropbox. Then getting it on my Ouya would be a snap.
NM. Went to the wiki page to look for the new version. Is it not librtmp.dll on android? I see files labeled librtmp.so
Yup - I appologize. I found the answer on the wiki.
OK. sorry so many posts. Hit a snag every step of the way. The path in the wiki does not exist on the Ouya, which is common. It doesn't seem to have the normal paths as most android devices. Looked through every folder and I can't find where librtmp.so is supposed to go.
I am using SMPC, newest version.
dkplayaclub no librtmp is not the same for all platforms. In windows is librtmp.dll , on androis is librtmp.so . They are diiferent binaries.
Hello all,
Mabs, could you please update the librtmp with the latest patch from RedPenguin updated 10-03-14 Fixed Tcommand&K on Gotham 13.2 stable version for Android. There is no apk exist with this updated librtmp atleast for 13.2 Gothan version.
I will need for my unrooted android device
Thanks in advance.
(2014-12-06, 09:21)afzal Wrote: [ -> ]Hello all,
@Mabs, could you please update the librtmp with the latest patch from RedPenguin updated 10-03-14 Fixed Tcommand&K on Gotham 13.2 stable version for Android. There is no apk exist with this updated librtmp atleast for 13.2 Gothan version.
Thanks in advance.
The last working file for Android is dated 30.08.2014.
The one you ask is not working in Android. That's why I don't use it.
I shared a few pages back a file APK with that 03.10 librtmp, and label it "not working". If you want to try...
(2014-12-06, 12:18)shuvro Wrote: [ -> ]@Mabs
Hi!
Can u pls replace new librtmp for this.
http://minix.com.hk/downfile/xbmcminix-a..._beta6.apk
Here is the file you asked,
xbmc for minix 13.3.3 beta6 with 30.08.2014 librtmp:
https://www.mediafire.com/?mh2amo4dvtol7h1
Hi guys, can someone tell me, which Cross-Compiler i take it to create librtmp.so.0 files for Raspberry Pi with OpenELEC 4.97.2 (arm)?
I compile under Win7 x64 with last MinGW.
thanks
Sorry, but if I could get some help updating the latest librtmp for FireTV in a simplified form. I've tried to understand how to do this, but I really am not a advanced as most when it comes to this sort of thing and since I am not using a PC or MAC but Android Arm instead, I really don't understand how to replace the old librtmp. I am on the latest Kodi 13.2.
Thanks in advance.
(2014-12-14, 13:41)#Noe Wrote: [ -> ]Hi guys, can someone tell me, which Cross-Compiler i take it to create librtmp.so.0 files for Raspberry Pi with OpenELEC 4.97.2 (arm)?
thanks
A cross-compiler guide step-by-step would be awesome!
Now that RedPenguin has been away with his own real life problems, it would be great if someone could give some pointers on how to do it...
I hope RP (or others) can read this and help ...
EDIT:
SPMC (13.4.0) with LibRTMP 30.08.2014:
https://www.mediafire.com/?z8i81dt6qco6k7z
SPMC (13.4.0) (Launcher) with LibRTMP 30.08.2014
http://www.mediafire.com/?jrofs9n8nymkga5
