2013-04-14, 00:24
2013-04-14, 05:11
Are you getting the correct timeline in NextPVR's own TV Guide?
What EPG source are you using?
2013-04-14, 06:53
(2013-04-14, 05:11)sub3 Wrote: [ -> ]Are you getting the correct timeline in NextPVR's own TV Guide?
NextPVR EPG is not working too. just using the DVB-T source.
2013-04-14, 07:24
That's odd. I'm not aware of any other users with this problem. Are you sure you've got the timezone settings and time set correctly on your PC?
2013-04-15, 06:28
(2013-04-14, 07:24)sub3 Wrote: [ -> ]That's odd. I'm not aware of any other users with this problem. Are you sure you've got the timezone settings and time set correctly on your PC?Yes. My system time has been changed. Don't know how that has happened. Anyway I changed it to correct time and restarted Win7.
Still EPG not working well, its missing EPG data both in NPVR and XBMC.
2013-04-15, 07:43
(2013-04-15, 06:28)anibeasts Wrote: [ -> ]Ok, great.(2013-04-14, 07:24)sub3 Wrote: [ -> ]That's odd. I'm not aware of any other users with this problem. Are you sure you've got the timezone settings and time set correctly on your PC?Yes. My system time has been changed. Don't know how that has happened. Anyway I changed it to correct time and restarted Win7.
Quote:Still EPG not working well, its missing EPG data both in NPVR and XBMC.If hitting 'empty epg' followed by 'update epg' doesn't fix it, then post the npvr.log and I'll take a look.
