2013-04-14, 07:35
here's what i get when i try to run sudo apt-get dist upgrade. does anyone know why? ive updated in the past but now it doesnt seem to work, do i have a bad install?
thanks!
sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
xbmc xbmc-bin
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/35.6 MB of archives.
After this operation, 5,048 kB of additional disk space will be used.
Do you want to continue [Y/n]?
(Reading database ... 187207 files and directories currently installed.)
Preparing to replace xbmc 2:12.0~git20130128.1315-frodo-0quantal (using .../xbmc_3%3a12.9.3-git201304112044~a30966e-1~ppa1~quantal_all.deb) ...
Unpacking replacement xbmc ...
dpkg: error processing /var/cache/apt/archives/xbmc_3%3a12.9.3-git201304112044~a30966e-1~ppa1~quantal_all.deb (--unpack):
trying to overwrite '/usr/share/xbmc/addons/pvr.hts/addon.xml', which is also in package xbmc-pvr-tvheadend-hts 1.7.19-2quantal
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to replace xbmc-bin 2:12.0~git20130128.1315-frodo-0quantal (using .../xbmc-bin_3%3a12.9.3-git201304112044~a30966e-1~ppa1~quantal_i386.deb) ...
Unpacking replacement xbmc-bin ...
dpkg: error processing /var/cache/apt/archives/xbmc-bin_3%3a12.9.3-git201304112044~a30966e-1~ppa1~quantal_i386.deb (--unpack):
trying to overwrite '/usr/lib/xbmc/addons/pvr.hts/XBMC_Tvheadend.pvr', which is also in package xbmc-pvr-tvheadend-hts 1.7.19-2quantal
Processing triggers for python-support ...
Processing triggers for man-db ...
Processing triggers for hicolor-icon-theme ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
thanks!
xbmc xbmc-bin
