Full Version: Adding media case 'tags'?
So I noticed this part in the FAQ:
Quote:4. How do I get that skin show me Media Cases ?
A: Ace use the 'tags' on the file name or folder to determine the type of case as follows:
bluray - blu-ray - bdrip (without 3d or 3dbd tag) = Bluray box
bluray - blu-ray - bdrip + 3d or 3dbd = 3D box
3d - 3dbd = 3D box
web = Web box
hdtv = HDTV box
dvd - .iso (without bluray or any other tag) - .ifo = dvd box
All others contents = default box + codec
And I was wondering, is there any way I can edit whatever files holds this information, and add SD, 480, 720, and 1080 to the tags, rather than re-do my library set up to match the tags?
I'm fairly decent at figuring this stuff out, if someone could give me a push on where to look. Thanks!
There are programs to rename batch, is the best way.
