2013-04-14, 22:42
I just updated a bunch of packages on my Ubuntu 12.04 LTS Mac Mini to get up to date and now XBMC 12.1 (and only XBMC) is using nearly 100% of my CPU in idle. I've enabled debug (log here), but I don't see much activity while the system is sitting idle. It's quite repeatable and keeps happening across a few reboots. I've tried creating new profiles, switching between skins, and moving my entire .xbmc directory out of the way to force it to create a new one. I've also tried the nightly builds and they're behaving the same way (I've since reverted back to 12.1). I've removed and reinstalled XBMC without any change. I ran an strace on the XBMC PID for fun, but it just appears to be sitting in an event loop from a system call perspective (log here).
Is there anything else that I can do to try to track this down? I have a list of all of the packages that were updated before this started happening, but it was quite a few and I'm not sure what to look for.
I usually avoid doing gratuitous OS upgrades on my HTPC because of this sort of thing, but I hoped that an LTS release would make it safer overall.
EDIT: Ah, problem solved by re-installing the NVidia drivers (up to v310.44 now). Luckily it was an easy fix. I'll leave this post up in case someone else sees this issue.
