Full Version: Janitor
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
Exclusions are indeed being ignored. I'm using a source on a Windows network share.
Please provide me with debug logs so that I may find the root of the problem.
(2016-03-29, 14:51)Anthirian Wrote: [ -> ]Please provide me with debug logs so that I may find the root of the problem.
I sent you the Pastebin links in a PM, hope that's acceptable.
Hi, this addon worked perfectly for me until I added some shows with Russian Cyrillic characters. I'm not sure if this is supposed to happen or not but I was wondering if you can help. Kodi reads/displays them just fine if that matters.
Here is the log of the error:
NOTICE: Skin Helper Service --> skin helper service version 1.0.68 started
NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                      Error Type: <type 'exceptions.UnicodeDecodeError'>
                      Error Contents: 'utf8' codec can't decode byte 0xc1 in position 0: invalid start byte
                            File "C:\..\script.filecleaner-master\service.py", line 47, in <module>autostart()
                            File "C:\..\script.filecleaner-master\service.py", line 33, in autostart results, _ = cleaner.clean_all()
                            File "C:\..\script.filecleaner-master\default.py", line 233, in clean_all cleaned_files, count, status = self.clean(video_type)
                            File "C:\..\script.filecleaner-master\default.py", line 141, in clean expired_videos = self.get_expired_videos(video_type)
                            File "C:\..\script.filecleaner-master\default.py", line 335, in get_expired_videos result = json.loads(response)
                            File "C:..\Kodi\system\python\Lib\json\__init__.py", line 338, in loads return _default_decoder.decode(s)
                            File "C:\..\Kodi\system\python\Lib\json\decoder.py", line 366, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end())
                            File "C:\..\Kodi\system\python\Lib\json\decoder.py", line 382, in raw_decode obj, end = self.scan_once(s, idx)
                            UnicodeDecodeError: 'utf8' codec can't decode byte 0xc1 in position 0: invalid start byte
Thanks for any help you can provide!
Thanks for posting your logs. It looks like this is an issue with the JSON module shipped with Kodi. I'm not sure if I am able to fix this issue by myself, but I will look into it.
Simply question....... on my OSMC installation i have checked by Filezilla and i have access to many addons folder and i have watched i have some double and in some cases triple folder about some addons (for example the youtube addons i have upgraded manually installed by zip maintained in this forum) and also on userdate/addons i have folder like addons unistalled to many time ago.
You thinks i can use this cleaner to make some cleaning on my OMSC installation Huh Or you thinks it's better every 6 o 7 months it's better to make a clean installation from beginning ?
(2016-04-07, 16:53)Anthirian Wrote: [ -> ]Thanks for posting your logs. It looks like this is an issue with the JSON module shipped with Kodi. I'm not sure if I am able to fix this issue by myself, but I will look into it.
Yeah, I think you're right. Unfortunately even when I try to exclude the paths (using the GUI), it still pulls in the files with videolibrary.geteposides or .getmovies, and then checks if the path is excluded afterwards which still throws the error. Is there a particular reason that you don't exclude the paths using a filter prior to the videolibrary.get as opposed to checking afterwards if the episode is excluded?
I was thinking about possibly trying to add something in myself like "by_path = {"field": "path", "operator": "doesnotcontain", "value": ""}" and then appending that to the filter list before it calls videolibrary.getepisodes to solve this issue on my own. But I don't know much about programming and not sure if that would just break the whole addon.
Hey,
I'm having trouble running the cleaning service. I tried defaulting the settings, reinstalling with removing the settings from my profile but nothing works.
Am I doing something wrong or missing a dependency or something?
This is running Kodi (16.0 Git:2016-03-11-a3eb4fa) on Xbian XBian 1.0 (knockout), kernel: Linux ARM 32-bit version 4.4.7+
22:19:18 189.574554 T:1603265456   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.NameError'>
                                            Error Contents: global name 'monitor' is not defined
                                              File "/home/xbian/.kodi/addons/script.filecleaner/service.py", line 47, in <module>
                                                autostart()
                                              File "/home/xbian/.kodi/addons/script.filecleaner/service.py", line 33, in autostart
                                              File "/home/xbian/.kodi/addons/script.filecleaner/default.py", line 247, in clean_all
                                                monitor.waitForAbort(2)  # Sleep 2 seconds to make sure file I/O is done.
                                            NameError: global name 'monitor' is not defined
22:19:18 189.659180 T:1603265456 WARNING: CPythonInvoker(5, /home/xbian/.kodi/addons/script.filecleaner/service.py): the python script "/home/xbian/.kodi/addons/script.filecleaner/service.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui14DialogProgressE
edit:
Can't repro it anymore... I work in IT so this happens to a lot of my clients aswell:
- I removed the addon, /.kodi/addons/script.filecleaner/ and /.kodi/userdata/addon_data/script.filecleaner again.
- Restarted the device again
- Reinstalled and reconfigured Janitor
Now it works fine. Please note that I did all this before. Lets just call it a layer 8 problem... Thanks for listening and if it happens again I will update.
(2016-04-08, 01:54)DjDiabolik Wrote: [ -> ]Simply question....... on my OSMC installation i have checked by Filezilla and i have access to many addons folder and i have watched i have some double and in some cases triple folder about some addons (for example the youtube addons i have upgraded manually installed by zip maintained in this forum) and also on userdate/addons i have folder like addons unistalled to many time ago.
I'm afraid Janitor cannot help you with this. It will only clean actual video files and does not have access to other addons' files.
(2016-04-12, 20:47)chubbs Wrote: [ -> ]
That's actually not a bad idea. I'll definitely look into that. I have already made some performance improvements in this area, but this looks like another solid improvement. Hopefully this will also resolve your issue. I'll try to push a small update for this later this month, or early next month. If you could test it before I update the repository with the new version that would be great.
(2016-04-22, 19:30)YoYoost Wrote: [ -> ]Hey,
                                                autostart()
That sure looks strange. Unfortunately I cannot determine the cause by just this snippet of the log. Could you please enable debug logging in Janitor's settings and post the entire log on Pastebin?
Contrary to my last edit it did fail again, is it OK if I PM you a Pastebin?
(2016-04-22, 21:18)Anthirian Wrote: [ -> ]
                                                autostart()
I have got the same error on Kodi for Windows. Would you like me to send the log file?
I am having problems cleaning up files/folders with special characters in the name.
Log is here:
http://xbmclogs.com/pfzdyoqdu
The files are on a Synology NAS and are accessed from my Nvidia Shield TV (Android) via SMB.
Thanks for your help!
have the following error I can't get over.
May you help me. Love your addon!!!
08:02:21 280.952942 T:1756361632   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.UnicodeEncodeError'>
                                            Error Contents: 'ascii' codec can't encode character u'\xe4' in position 34: ordinal not in range(128)
                                              File "/storage/.kodi/addons/script.filecleaner/default.py", line 699, in <module>
                                                results, return_status = cleaner.clean_all()
                                              File "/storage/.kodi/addons/script.filecleaner/default.py", line 233, in clean_all
                                              File "/storage/.kodi/addons/script.filecleaner/default.py", line 198, in clean
                                                self.progress.update(int(progress_percent), translate(32616).format(amount=amount, type=type_translation[video_type]), translate(32617), "[I]{0!s}[/I]".format(title))
                                            UnicodeEncodeError: 'ascii' codec can't encode character u'\xe4' in position 34: ordinal not in range(128)
08:02:22 281.025513 T:1756361632 WARNING: CPythonInvoker(4, /storage/.kodi/addons/script.filecleaner/default.py): the python script "/storage/.kodi/addons/script.filecleaner/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon7xbmcgui14DialogProgressE
I have just pushed two commits that look like they fix the issues you guys were having with running as a service and foreign language titles. Could you please download the latest version from Github and use this to test if your problem has been solved?
(2016-05-12, 18:00)Anthirian Wrote: [ -> ]I have just pushed two commits that look like they fix the issues you guys were having with running as a service and foreign language titles. Could you please download the latest version from Github and use this to test if your problem has been solved?
This seems to have fixed it after 1 viewed video, will keep checking.
Thanks for looking into this!
edit:
It keeps working as intended without throwing errors in kodi.log so the issue is definitely fixed.
