2016-10-02, 23:03
First of all, apologies for not responding sooner. I have taken up a new full time job recently and don't have that much time for Janitor anymore.
Could you try deleting this episode manually and trying again?
(2016-07-05, 18:50)mels0n Wrote: [ -> ]Every time I run Janitor it locks up and I get the following in the log:From this error message I understand there is a problem with the second file in the results set. It looks like the title scraped into the library for the episode White Collar 6x02 contains some unicode characters that result in an error when processed by Janitor. I'm not sure why this happens. I have performed various tests scraping a movie into my library using the Russian and Korean titles, but these are in fact cleaned up successfully:
Code:11:27:26 629.741699 T:1766851568 NOTICE: Janitor: Starting cleaning routine.
11:27:27 629.793152 T:1766851568 NOTICE: Janitor: Cleaning of 'movies' is disabled. Skipping.
11:27:27 629.810242 T:1766851568 NOTICE: Janitor: Cleaning of 'musicvideos' is disabled. Skipping.
11:27:27 629.899780 T:1766851568 NOTICE: Janitor: [VideoLibrary.GetEpisodes] Filters enabled: [{'operator': 'greaterthan', 'field': 'playcount', 'value': '0'}, {'operator': 'notinthelast', 'field': 'lastplayed', 'value': '30.000000'}, {'operator': 'false', 'field': 'inprogress', 'value': ''}]
11:27:28 631.583740 T:1766851568 NOTICE: Janitor: [VideoLibrary.GetEpisodes] Response: '{"id":1,"jsonrpc":"2.0","result":{"episodes":[{"episodeid":2,"file":"nfs://192.168.1.200/Torrents/TV Shows/White Collar/Season 06/White Collar - S06E01 - Borrowed Time.mkv","label":"6x01. Borrowed Time","showtitle":"White Collar"},{"episodeid":3,"file":"nfs://192.168.1.200/Torrents/TV Shows/White Collar/Season 06/White Collar - S06E02 - Return to Sender.mkv","label
11:27:28 631.614441 T:1766851568 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'utf8' codec can't decode byte 0xe2 in position 85: invalid continuation byte
File "/home/osmc/.kodi/addons/script.filecleaner/service.py", line 46, in <module>
autostart()
File "/home/osmc/.kodi/addons/script.filecleaner/service.py", line 32, in autostart
results, _ = cleaner.clean_all()
File "/home/osmc/.kodi/addons/script.filecleaner/default.py", line 234, in clean_all
cleaned_files, count, status = self.clean(video_type)
File "/home/osmc/.kodi/addons/script.filecleaner/default.py", line 140, in clean
expired_videos = self.get_expired_videos(video_type)
File "/home/osmc/.kodi/addons/script.filecleaner/default.py", line 342, in get_expired_videos
result = json.loads(response)
File "/usr/lib/python2.7/json/__init__.py", line 338, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
obj, end = self.scan_once(s, idx)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xe2 in position 85: invalid continuation byte
11:27:29 631.824890 T:1766851568 WARNING: CPythonInvoker(2, /home/osmc/.kodi/addons/script.filecleaner/service.py): the python script "/home/osmc/.kodi/addons/script.filecleaner/service.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon4xbmc7MonitorE,N9XBMCAddon7xbmcgui14DialogProgressE
22:41:33 T:10208 NOTICE: Janitor: [VideoLibrary.GetMovies] Filters enabled: [{'operator': 'greaterthan', 'field': 'playcount', 'value': '0'}, {'operator': 'false', 'field': 'inprogress', 'value': ''}, {'operator': 'doesnotcontain', 'field': 'path', 'value': 'nfs://192.168.0.3/mnt/storage/downloads/'}, {'operator': 'doesnotcontain', 'field': 'path', 'value': 'E:\\Downloads\\Unsorted\\Misc\\'}]
22:41:33 T:10208 DEBUG: CVideoDatabase::RunQuery took 4 ms for 1 items query: select * from movie_view WHERE ((CAST(movie_view.playCount as DECIMAL(5,1)) > 0)) AND (movie_view.idFile NOT IN (SELECT DISTINCT idFile FROM bookmark WHERE type = 1)) AND ((movie_view.strPath NOT LIKE '%nfs://192.168.0.3/mnt/storage/downloads/%' OR movie_view.strPath IS NULL)) AND ((movie_view.strPath NOT LIKE '%E:\Downloads\Unsorted\Misc\%' OR movie_view.strPath IS NULL))
22:41:33 T:10208 NOTICE: Janitor: [VideoLibrary.GetMovies] Response: '{"id":1,"jsonrpc":"2.0","result":{"limits":{"end":1,"start":0,"total":1},"movies":[{"file":"E:\\\\Downloads\\\\Unsorted\\\\Movies\\\\Schindlers.List.1080p.BluRay.x264-SPARKS\\\\Schindlers.List.1080p.BluRay.x264-SPARKs.mkv","label":"\xec\x89\xb0\xeb\x93\xa4\xeb\x9f\xac \xeb\xa6\xac\xec\x8a\xa4\xed\x8a\xb8","movieid":375,"title":"\xec\x89\xb0\xeb\x93\xa4\xeb\x9f\xac \xeb\xa6\xac\xec\x8a\xa4\xed\x8a\xb8"}]}}'
22:41:33 T:10208 NOTICE: Janitor: Building list of expired videos
22:41:33 T:10208 NOTICE: Janitor: Found 1 watched movies matching your conditions
22:41:33 T:10208 NOTICE: Janitor: JSON Response: {u'movies': [{u'title': u'\uc270\ub4e4\ub7ec \ub9ac\uc2a4\ud2b8', u'movieid': 375, u'file': u'E:\\Downloads\\Unsorted\\Movies\\Schindlers.List.1080p.BluRay.x264-SPARKS\\Schindlers.List.1080p.BluRay.x264-SPARKS.mkv', u'label': u'\uc270\ub4e4\ub7ec \ub9ac\uc2a4\ud2b8'}], u'limits': {u'start': 0, u'total': 1, u'end': 1}}
22:41:33 T:10208 NOTICE: Janitor: Expired videos: [[u'E:\\Downloads\\Unsorted\\Movies\\Schindlers.List.1080p.BluRay.x264-SPARKS\\Schindlers.List.1080p.BluRay.x264-SPARKS.mkv', u'\uc270\ub4e4\ub7ec \ub9ac\uc2a4\ud2b8']]
22:41:33 T:10208 NOTICE: Janitor: Found 1 videos that may need cleaning.
22:41:33 T:10208 NOTICE: Janitor: Unstacking 'E:\\Downloads\\Unsorted\\Movies\\Schindlers.List.1080p.BluRay.x264-SPARKS\\Schindlers.List.1080p.BluRay.x264-SPARKS.mkv' is not needed.
22:41:33 T:10208 NOTICE: Previous line repeats 1 times.
22:41:33 T:10208 NOTICE: Janitor: Attempting to move 'E:\\Downloads\\Unsorted\\Movies\\Schindlers.List.1080p.BluRay.x264-SPARKS\\Schindlers.List.1080p.BluRay.x264-SPARKS.mkv' to 'E:\\Downloads\\Unsorted\\Expired\\\xec\x89\xb0\xeb\x93\xa4\xeb\x9f\xac \xeb\xa6\xac\xec\x8a\xa4\xed\x8a\xb8'.
22:41:33 T:10208 NOTICE: Janitor: Created destination 'E:\\Downloads\\Unsorted\\Expired\\\xec\x89\xb0\xeb\x93\xa4\xeb\x9f\xac \xeb\xa6\xac\xec\x8a\xa4\xed\x8a\xb8'.
22:41:33 T:10208 NOTICE: Janitor: Moving 'E:\\Downloads\\Unsorted\\Movies\\Schindlers.List.1080p.BluRay.x264-SPARKS\\Schindlers.List.1080p.BluRay.x264-SPARKS.mkv' to 'E:\\Downloads\\Unsorted\\Expired\\\xec\x89\xb0\xeb\x93\xa4\xeb\x9f\xac \xeb\xa6\xac\xec\x8a\xa4\xed\x8a\xb8\\Schindlers.List.1080p.BluRay.x264-SPARKS.mkv'.
22:41:33 T:10208 NOTICE: Janitor: File(s) moved successfully.
(2016-07-27, 11:13)matt666 Wrote: [ -> ]I'm having a similar problem to the user above where exclusions are no longer working - not a massive problem for me as I only have Janitor enabled on TV Series, and the only thing I want to keep is a folder of a kids TV show for my kids.
It's running on a Synology NAS and I had the idea that I'd just set the permissions on that folder to Read Only, however the files still get deleted. Does the Janitor process use the root account to carry out it's delete operation?
Is there anything I can do to preserve this folder?
(2016-07-27, 20:35)matt666 Wrote: [ -> ]This is weirder than I thought, the episodes don't delete when I kick off Janitor manually but they do disappear if they have a watched status and the system kicks off an automatic sweep. Nothing in the logs to say they've been deleted either.I'm not quite sure why this happens for you. Janitor runs within Kodi, not with elevated privileges, so if it is deleting something that is read only, I suspect it might be a bug within Kodi's python API. Could you show me a log that shows this behavior?
(2016-09-01, 19:28)i3laze Wrote: [ -> ]Thanks for your efforts!As explained above my time has become limited, so I unfortunately don't have the time to keep compabitility with older versions of Kodi. Maybe if you were to post a log I could point you in the right direction.
Would you please publish the old version, that still supports Gotham?
Got "Dependencies not met" installing on Gotham box (PrismCube).
UPD: Found it: https://github.com/Anthirian/script.file...r/releases
Is 4.0.1 the latest to work on Gotham?
UPD: Yes.
I got the bug with log not being created - should I downgrade to 4.0.0? Or.. Whats's the filename and path for the log file? (I will create it manually)
UPD: The log is up and running at "./mnt/hdd0/program/.xbmc/userdata/addon_data/script.filecleaner/cleaner.log",
yet when i press "View cleaning history" from the app the log window does not popup : (
P.S. Sorry for self-talk.. just wonder why I had log window working previously (before i reinstalled XMBC).
(2016-09-19, 02:26)kbaudi Wrote: [ -> ]Do you plan to update Janitor for Kodi 17 betas, or do we need to wait for the official Kodi release?I'm not planning to update it for the betas, so your best bet is to wait until Kodi 17 is released and I update the addon. It may take a while before it is updated however, since as I mentioned above, I now have a full time job that takes up most of my time.
