2013-04-18, 02:45
2013-04-18, 07:48
Adjust the xbmc audio settings properly.
2013-04-18, 11:12
Use this thread http://forum.xbmc.org/showthread.php?tid=146911 to make sure audio is configured correctly.
Is your signature the correct specs for your HTPC? just want to be sure you're using Nvidia graphics as there is a problem with AMD drivers that could also cause this, but obviously not applicable if you haven't got a AMD GPU.
