2013-04-18, 07:10
Is there a way to set xbmc to stop trying to load a video stream after a certain amount of seconds? I use xbmc mainly for the video plugins and some times when trying to load a video stream it freezes xbmc or takes to long for xbmc to tell you that it has failed to play. Not sure if there is some kind of code you can use in the advancesettings.xml in order to do this.
