Full Version: Emprex 3009URF Remote Control - can I get this to work with XBMC?
I have just bought a Raspberry PI and have finally got Raspbmc up and running.
I am currently using an Emprex 3009URF remote control and althought the basic buttons are working fine, it would be nice if the recording button, epg button etc. also worked.
Is there any way to get this working with XBMC or should I consider buying a cheap version, from E-Bay, that works staright out of the box?
I used to use the remote with Mediaportal and was only able to get that to work with Event Ghost.
A
