2013-04-20, 11:28
Hi Folks
Im not sure, if I am posting in the right section. It seemed to be the right one I am having a problem with XBMC 13 (Gotham) when trying to install it on xbmcubuntu. When xbmc starts up, there's no image only a black screen appearing. Somehow it doesnt matter what Gotham Version I use, its always the same result. I tested it with the official xbmc unstable ppa and actualy I am using FernetMentas's Git repo. Xbmc itselfs starts up, so that the process appears to be running, also I can hear the menu-sounds. It's also not possible that the tv/display i am using has problems with the resolution or the syncing, since I tested it with another display.
When I kill XBMC using:
lightdm appears propperly on the screen.
I've got the follwoing Graphics interfaces:
I am using the nvidia-graphics output and nvidia-current and nvidia-common are installed. Following the logs of syslog xorg and xbmc:
xbmc log:
http://pastebin.com/xVPBu0st
syslog
http://pastebin.com/6hMJTdRR
xorg.log
http://pastebin.com/061gBdv1
Perhaps some of you, have had the same issues with Gotham.
killall xbmc-standalone
*-display
description: VGA compatible controller
product: GF108 [GeForce GT 430]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:16 memory:fa000000-faffffff memory:d0000000-d7ffffff memory:d8000000-d9ffffff ioport:e000(size=128) memory:fb000000-fb07ffff
*-display
description: Display controller
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list
configuration: driver=i915 latency=0
resources: irq:47 memory:fb400000-fb7fffff memory:c0000000-cfffffff ioport:f000(size=64)
xbmc log:
syslog
xorg.log
