Full Version: Playing 1080 mkv with XBMC 12
I'm using Asus Transformer TF300T with XBMC 12.
I've just try playing a 1080 MKV but it's not smooth and frame rate is about 12 images/sec.
The same video play fine with MXPlayer.
I didn' find any video option in XBMC to use hardware decoder.
Do I have to use MXplayer as an external player ?
Try the libstagefright build which has experimental hardware decoding.
http://forum.xbmc.org/showthread.php?tid=152005
Alternatively, there are unofficial builds of xbmc that will use an external player. google: xbmc android user friendly.
Note that these builds don't work with smb shares. smb shares are used when you connect using android to files on a windows pc.
I will give a try this evening.
