Full Version: [RELEASE] GameTrailers.com
New addon for gametrailers.com.
Has support for all shows, reviews, previews, gameplay footage, interviews and so on..
I submitted this to xbmc repo last week, but figured i would make a forum post in case there are any issues/requests.
Version 1.0.0
- Initial release.
Version 1.0.1
- Check video uri before trying to play it.
- If prefered quality does not exist, fallback to highest quality.
nice thanks!!
thx alot.
THANK YOU THANK YOU THANK YOU!!!!
Iv been dying for something like this you seriously made my day
Hi, I recently updated the MyGica 1200 to the latest firmware and the supplied XBMC no longer seems to work with the GameTrailers plugin. When you select a video, "Working" appears then stops and nothing happens. I've uploaded a portion of the log file as hopefully someone will be able to help me out. If you need more info let me know and I'll post them.
Thank you in advance Smile
13:06:24 T:1505479368 NOTICE: DVDPlayer: Opening: rtmpe://cp152939.edgefcs.net/ondemand/mtvnorigin/gsp.gtcomstor/media/videos_root/shows/br/2013/715/gt_bonusround_ep715_a-block_1280x720_3500_h32.mp4
13:06:24 T:1505479368 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
13:06:24 T:1505479368 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
13:06:24 T:1505479368 DEBUG: LinuxRendererGL: Cleaning up GL resources
13:06:24 T:1505479368 DEBUG: SECTION:LoadDLL(libavutil-51-arm.so)
13:06:24 T:1505479368 DEBUG: Loading: /data/data/org.xbmc.xbmc/lib/libavutil-51-arm.so
13:06:24 T:1505479368 DEBUG: SECTION:LoadDLL(libswscale-2-arm.so)
13:06:24 T:1505479368 DEBUG: Loading: /data/data/org.xbmc.xbmc/lib/libswscale-2-arm.so
13:06:24 T:1646132016 NOTICE: Creating InputStream
13:06:24 T:1646132016 DEBUG: SECTION:LoadDLL(librtmp.so)
13:06:24 T:1646132016 DEBUG: Loading: /data/data/org.xbmc.xbmc/lib/librtmp.so
13:06:24 T:1646132016 INFO: : Using external libRTMP
13:06:24 T:1646132016 INFO: Parsing...
13:06:24 T:1646132016 INFO: Parsed protocol: 2
13:06:24 T:1646132016 INFO: Parsed host : cp152939.edgefcs.net
13:06:24 T:1646132016 INFO: Parsed app : ondemand
13:06:24 T:1646132016 INFO: RTMP_Connect1, ... connected, handshaking
13:06:24 T:1646132016 INFO: HandShake: Client type: 06
13:06:24 T:1646132016 INFO: HandShake: DH pubkey position: 622
13:06:24 T:1646132016 INFO: HandShake: Client digest offset: 1156
13:06:24 T:1646132016 INFO: HandShake: Initial client digest:
13:06:24 T:1646132016 INFO: // ***** Starring out the client digest from log
13:06:24 T:1562168768 INFO: Python script stopped
13:06:24 T:1505479368 DEBUG: ------ Window Init (DialogBusy.xml) ------
13:06:24 T:1505479368 DEBUG: Window DialogBusy.xml was already loaded
13:06:24 T:1505479368 DEBUG: Alloc resources: 0.06m
13:06:24 T:1505479368 DEBUG: waiting for python thread 9 (/storage/sdcard0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.gametrailerscom/addon.py) to stop
13:06:24 T:1505479368 DEBUG: python thread 9 (/storage/sdcard0/Android/data/org.xbmc.xbmc/files/.xbmc/addons/plugin.video.gametrailerscom/addon.py) destructed
13:06:24 T:1646132016 INFO: HandShake: Type Answer : 09
13:06:24 T:1646132016 WARNING: HandShake: Type mismatch: client sent 6, server answered 9
13:06:24 T:1646132016 INFO: HandShake: Server Uptime : 18849634
13:06:24 T:1646132016 INFO: HandShake: FMS Version : 4.5.2.1
13:06:24 T:1646132016 INFO: HandShake: Server DH public key offset: 478
13:06:24 T:1646132016 INFO: HandShake: Secret key:
13:06:24 T:1646132016 INFO: // ***** Starring out the key from log
13:06:24 T:1646132016 INFO: RC4 Out Key:
13:06:24 T:1646132016 INFO: RC4 In Key:
13:06:24 T:1646132016 INFO: HandShake: Calculated digest key from secure key and server digest:
13:06:24 T:1646132016 INFO: HandShake: Client signature calculated:
13:06:24 T:1646132016 INFO: HandShake: Server sent signature:
13:06:24 T:1646132016 INFO: HandShake: Digest key:
13:06:24 T:1646132016 INFO: HandShake: Signature calculated:
13:06:24 T:1646132016 WARNING: HandShake: Server not genuine Adobe!
13:06:24 T:1646132016 ERROR: RTMP_Connect1, handshake failed.
13:06:24 T:1646132016 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmpe://cp152939.edgefcs.net/ondemand/mtvnorigin/gsp.gtcomstor/media/videos_root/shows/br/2013/715/gt_bonusround_ep715_a-block_1280x720_3500_h32.mp4]
13:06:24 T:1646132016 NOTICE: CDVDPlayer::OnExit()
13:06:24 T:1646132016 NOTICE: CDVDPlayer::OnExit() deleting input stream
13:06:24 T:1505479368 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
13:06:24 T:1505479368 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
13:06:24 T:1505479368 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.gametrailerscom/play/http%3A%2F%2Fwww.gametrailers.com%2Ffeeds%2Fmediagen%2F%3Furi%3Dmgid%3Aarc%3Aepisode%3Agametrailers.com%3Ae97909d3-52fa-4106-b4ce-298d3cb92aa2/]
13:06:24 T:1505479368 DEBUG: Playlist Player: no more playable items... aborting playback
13:06:24 T:1505479368 NOTICE: CDVDPlayer::CloseFile()
13:06:24 T:1505479368 NOTICE: DVDPlayer: waiting for threads to exit
13:06:24 T:1505479368 NOTICE: DVDPlayer: finished waiting
mm no Hd support ?
@Row, the same file works fine on my ubuntu install. To me it looks like the issue is with librtmp.
zeromancer, eh? It supports any quality supplied by the site.
Thanks for looking into it N3MIS15,
I looked into updating librtmp but unfortunately I couldn't find the correct location on my Android box even after showing hidden files. Luckily, having changed back to the version of XBMC I was using prior to the hardware update the GT plugin is now playing again.
Well to bad the plugin crashes with every video 1/3th of the video
The plugin crashes or librtmp?
If your having issues provide a log so we can try to figure out the issue.
(2013-05-20, 23:00)N3MIS15 Wrote: [ -> ]The plugin crashes or librtmp?
here a link to the log http://xbmclogs.com/show.php?id=21002
(2013-05-21, 12:13)zeromancer Wrote: [ -> ]
The error was caused by librtmp. This is out of my control, sorry Sad.
Sorry, gt plugin work perfectly on Pc, but doesn't work on Android.. When select a video nothing matter... Can you help me?
edit: post wrong, I was asking for video plugin, not this..
