Full Version: Connection Lost Remote Machines
I was using Mediaportal TVserver before and have recently switched to Nextpvr. I keep getting "NEXTPVR pvr client connection lost" on all my xbmc client machines except to local pc that NextPvr server is on.
I`ve tried everything, any help would be greatly appreciated. Here's the log files from NextPvr on the [/php]main pc and from XBMC on the remote pc.
NEXTPVR.LOG
[/code][...startup]
2013-04-20 23:49:52.546 [DEBUG][1] Created mutex. Must be only instance.
2013-04-20 23:49:52.599 [DEBUG][1] Version: 2.6.2
2013-04-20 23:49:52.600 [DEBUG][1] SingleInstance()
2013-04-20 23:49:52.733 [INFO][1] About to connect to remote recording service
2013-04-20 23:49:52.734 [DEBUG][1] RecordingServiceProxy@exit
2013-04-20 23:49:52.756 [DEBUG][1] Using skin: C:\Users\Public\NPVR\skin\Default\
2013-04-20 23:49:52.760 [DEBUG][1] About to look for plugin directories in: C:\Users\Public\NPVR\Plugins\
2013-04-20 23:49:52.761 [DEBUG][1] Skipping non-existant plugin directory: C:\Program Files (x86)\NPVR\Plugins\
2013-04-20 23:49:52.766 [DEBUG][1] Loaded menu item: TV Guide
2013-04-20 23:49:52.790 [DEBUG][1] Loaded menu item: Recordings
2013-04-20 23:49:52.793 [DEBUG][1] Loaded menu item: Live TV
2013-04-20 23:49:52.794 [DEBUG][1] Loaded menu item: Search
2013-04-20 23:49:52.796 [DEBUG][1] Loaded menu item: Music
2013-04-20 23:49:52.798 [DEBUG][1] Loaded menu item: Videos
2013-04-20 23:49:52.800 [DEBUG][1] Loaded menu item: Pictures
2013-04-20 23:49:52.802 [DEBUG][1] Loaded menu item: DVD
2013-04-20 23:49:52.803 [DEBUG][1] Loaded menu item: Exit
2013-04-20 23:49:53.168 [DEBUG][1] Supports HardwareVertexProcessing
2013-04-20 23:49:53.168 [DEBUG][1] Supports PureDevice
2013-04-20 23:49:57.623 [INFO][3] Checking online for updated versions...
2013-04-20 23:49:57.623 [INFO][3] Web@1
2013-04-20 23:49:57.819 [INFO][3] Online check reports version info:
<version><component name="NextPVR" version="2.6.2" display="NextPVR 2.6.2"><url>http://forums.gbpvr.com/showthread.php?53816-2-6-2-available-(March-24th)</url></component></version>
2013-04-20 23:49:57.819 [INFO][3] current online version: 2.6.2
2013-04-20 23:49:57.819 [INFO][3] last notified version: 2.6.2
2013-04-20 23:50:00.981 [DEBUG][1] About to detect digital tuners
2013-04-20 23:50:00.985 [DEBUG][1] - 'Hauppauge WinTV-7164 BDA ATSC/QAM Tuner'
2013-04-20 23:50:00.986 [DEBUG][1] - 'Hauppauge WinTV 885 BDA Tuner/Demod'
2013-04-20 23:50:00.998 [DEBUG][1] About to check standards supported by 'Hauppauge WinTV 885 BDA Tuner/Demod'
2013-04-20 23:50:00.998 [DEBUG][1] Found IBDA_Topology
2013-04-20 23:50:00.998 [DEBUG][1] - KSNODE_BDA_RF_TUNER
2013-04-20 23:50:00.998 [DEBUG][1] - KSNODE_BDA_8VSB_DEMODULATOR
2013-04-20 23:50:00.998 [DEBUG][1] - KSNODE_BDA_QAM_DEMODULATOR
2013-04-20 23:50:00.998 [DEBUG][1] Done
2013-04-20 23:50:01.000 [DEBUG][1] About to check standards supported by 'Hauppauge WinTV-7164 BDA ATSC/QAM Tuner'
2013-04-20 23:50:01.000 [DEBUG][1] Found IBDA_Topology
2013-04-20 23:50:01.000 [DEBUG][1] - KSNODE_BDA_RF_TUNER
2013-04-20 23:50:01.000 [DEBUG][1] - KSNODE_BDA_8VSB_DEMODULATOR
2013-04-20 23:50:01.000 [DEBUG][1] - KSNODE_BDA_QAM_DEMODULATOR
2013-04-20 23:50:01.000 [DEBUG][1] Done
2013-04-20 23:50:01.002 [DEBUG][1] About to check standards supported by 'Hauppauge WinTV-7164 BDA ATSC/QAM Tuner'
2013-04-20 23:50:01.002 [DEBUG][1] Found IBDA_Topology
2013-04-20 23:50:01.002 [DEBUG][1] - KSNODE_BDA_RF_TUNER
2013-04-20 23:50:01.002 [DEBUG][1] - KSNODE_BDA_8VSB_DEMODULATOR
2013-04-20 23:50:01.002 [DEBUG][1] - KSNODE_BDA_QAM_DEMODULATOR
2013-04-20 23:50:01.002 [DEBUG][1] Done
2013-04-20 23:50:01.011 [DEBUG][1] About to check for HDPVR/Colossus/Siena tuners.
2013-04-20 23:50:01.019 [DEBUG][1] About to check for analog tuners
2013-04-20 23:50:01.027 [DEBUG][1] FindFilterByName failed to locate filter: MainConcept (HCW) MPEG Multiplexer-Plus
2013-04-20 23:50:01.027 [DEBUG][1] MainConcept mux not present. Disabling analog support.
2013-04-20 23:50:29.161 [DEBUG][1] Frame Render Rate=13.9760255813599
2013-04-20 23:50:29.681 [DEBUG][1] storing Position (1):2,1
2013-04-20 23:50:29.681 [DEBUG][1] storing Size (1):1022,667
2013-04-20 23:50:29.689 [INFO][1] Exiting...
2013-04-20 23:50:29.689 [INFO][1] Done.
NRECORD.LOG
[/quote][...startup]
2013-04-21 00:38:19.453 [DEBUG][5] MVPManager thread started
2013-04-21 00:38:19.454 [DEBUG][5] MVP Server: C:\Program Files (x86)\NPVR\NextPVR.exe
2013-04-21 00:38:19.454 [DEBUG][5] Starting MVP server 0
2013-04-21 00:38:19.458 [DEBUG][4] OnStart()
2013-04-21 00:38:19.469 [INFO][4] Using local in-process recording service
2013-04-21 00:38:19.865 [DEBUG][4] RecordingServiceProxy@exit
2013-04-21 00:38:19.903 [INFO][4] RecordingService.Startup()
2013-04-21 00:38:19.903 [INFO][4] Starting remoting service
2013-04-21 00:38:19.923 [DEBUG][9] Requesting wake up for 'EPGWAKEUP' at 4/21/2013 2:00 AM
2013-04-21 00:38:19.932 [INFO][4] Starting web server on: 8866
2013-04-21 00:38:19.932 [INFO][4] Setting working directory to: C:\Program Files (x86)\NPVR\
2013-04-21 00:38:19.932 [INFO][4] Web root: C:\Users\Public\NPVR\web
2013-04-21 00:38:19.949 [INFO][8] RecordingService starting...
2013-04-21 00:38:19.953 [DEBUG][8] PurgeOldDeletes()
2013-04-21 00:38:19.953 [DEBUG][8] Loading recording schedule
2013-04-21 00:38:19.961 [DEBUG][8] CancelAllWakeupRequests
2013-04-21 00:38:20.937 [DEBUG][4] OnStart() complete...
2013-04-21 00:38:24.923 [DEBUG][10] Client Listener starting on port 7969
XBMC
[code]00:12:13 T:7984 NOTICE: PVRManager - starting up
00:12:13 T:7364 NOTICE: Thread CTCPServer start, auto delete: false
00:12:13 T:9356 NOTICE: Thread PVR manager start, auto delete: false
00:12:13 T:1196 NOTICE: Thread PVR add-on updater start, auto delete: false
00:12:13 T:1196 DEBUG: PVR::CPVRClients::RegisterClient - registering add-on 'NextPVR PVR Client'
00:12:13 T:1196 DEBUG: PVR - PVR::CPVRClient::Create - creating PVR add-on instance 'NextPVR PVR Client'
00:12:13 T:1196 DEBUG: ADDON: Dll Initializing - NextPVR PVR Client
00:12:13 T:1196 DEBUG: SECTION:LoadDLL(C:\Program Files (x86)\XBMC\addons\pvr.nextpvr\XBMC_NextPVR_win32.dll)
00:12:13 T:1196 DEBUG: LoadLibraryExA called with flags:
- LOAD_WITH_ALTERED_SEARCH_PATH
00:12:13 T:1196 DEBUG: Previous line repeats 1 times.
00:12:13 T:1196 INFO: AddOnLog: NextPVR PVR Client: Creating NextPVR PVR-Client
00:12:13 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'host'
00:12:13 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'port'
00:12:13 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'pin'
00:12:13 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'usetimeshift'
00:12:13 T:1196 DEBUG: AddOnLog: NextPVR PVR Client: settings: host='192.168.1.112', port=8866
00:12:13 T:1196 DEBUG: CFileCache::Open - opening <service> using cache
00:12:13 T:1196 DEBUG: CurlFile::Open(0923A2C8) http://192.168.1.112:8866/service?method...evice=xbmc
00:12:13 T:1196 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://192.168.1.112
00:12:13 T:5376 NOTICE: Thread CRssReader start, auto delete: false
00:12:13 T:5376 DEBUG: CurlFile::Open(0B25FB08) http://feeds.xbmc.org/xbmc
00:12:13 T:5376 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://feeds.xbmc.org
00:12:13 T:3572 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
00:12:13 T:8480 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
00:12:13 T:8480 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
00:12:13 T:8480 DEBUG: CMusicDatabase::GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
00:12:13 T:8480 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
00:12:13 T:8480 DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 10
00:12:13 T:8480 DEBUG: CVideoDatabase::RunQuery took 1 ms for 0 items query: select * from episodeview ORDER BY dateAdded desc, idEpisode desc LIMIT 10
00:12:13 T:8480 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from musicvideoview ORDER BY dateAdded desc, idMVideo desc LIMIT 10
00:12:13 T:8480 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
00:12:14 T:5376 DEBUG: Got rss feed: http://feeds.xbmc.org/xbmc
00:12:14 T:5376 DEBUG: RSS feed encoding: UTF-8
00:12:14 T:5376 DEBUG: Parsed rss feed: http://feeds.xbmc.org/xbmc
00:12:14 T:5376 DEBUG: Thread CRssReader 5376 terminating
00:12:14 T:2632 DEBUG: CRemoteControl::Connect - failed to connect
00:12:14 T:2632 INFO: CRemoteControl:Tonguerocess - failed to connect to irss, will keep retrying every 5 seconds
00:12:18 T:3572 DEBUG: ------ Window Deinit (Pointer.xml) ------
00:12:22 T:1700 DEBUG: CAESinkDirectSound:Big Grineinitialize: Cleaning up
00:12:22 T:1700 DEBUG: Suspended the Sink
00:12:23 T:1196 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
00:12:23 T:1196 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:12:23 T:1196 ERROR: XFILE::CFileCache::Open - failed to open source <http://192.168.1.112:8866/service?method=session.initiate&ver=1.0&device=xbmc>
00:12:23 T:1196 DEBUG: AddOnLog: NextPVR PVR Client: ->~cPVRClientNextPVR()
00:12:23 T:1196 ERROR: ADDON: Dll NextPVR PVR Client - Client returned bad status (1) from Create and is not usable
00:12:23 T:1196 INFO: Called Add-on status handler for '1' of clientName:NextPVR PVR Client, clientID:pvr.nextpvr (same Thread=no)
00:12:23 T:1196 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on NextPVR PVR Client, status = 1
00:12:23 T:6960 NOTICE: Thread CAddonStatusHandler:pvr.nextpvr start, auto delete: true
00:12:23 T:6960 DEBUG: Thread CAddonStatusHandler:pvr.nextpvr 6960 terminating (autodelete)
00:12:23 T:3572 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
00:12:23 T:1700 DEBUG: Resumed the Sink
00:12:23 T:1700 DEBUG: CSoftAE::Run - Sink restart flagged
00:12:23 T:1700 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
00:12:23 T:1700 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 1836328
00:12:23 T:1700 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
00:12:23 T:1700 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
00:12:23 T:1700 DEBUG: Audio Device : Speakers (Conexant Pebble High Definition SmartAudio)
00:12:23 T:1700 DEBUG: Sample Rate : 44100
00:12:23 T:1700 DEBUG: Sample Format : AE_FMT_FLOAT
00:12:23 T:1700 DEBUG: Bits Per Sample : 32
00:12:23 T:1700 DEBUG: Valid Bits/Samp : 32
00:12:23 T:1700 DEBUG: Channel Count : 2
00:12:23 T:1700 DEBUG: Block Align : 8
00:12:23 T:1700 DEBUG: Avg. Bytes Sec : 352800
00:12:23 T:1700 DEBUG: Samples/Block : 32
00:12:23 T:1700 DEBUG: Format cBSize : 22
00:12:23 T:1700 DEBUG: Channel Layout : FL,FR
00:12:23 T:1700 DEBUG: Channel Mask : 3
00:12:23 T:1700 DEBUG: Frames : 441
00:12:23 T:1700 DEBUG: Frame Samples : 882
00:12:23 T:1700 DEBUG: Frame Size : 8
00:12:23 T:1700 DEBUG: CSoftAE::InternalOpenSink - DirectSound Initialized:
00:12:23 T:1700 DEBUG: Output Device : Speakers - Speakers (Conexant Pebble High Definition SmartAudio)
00:12:23 T:1700 DEBUG: Channel Layout: FL,FR
00:12:23 T:1700 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
00:12:23 T:1700 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 3528
00:12:24 T:1700 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
00:12:24 T:1196 DEBUG: PVR::CPVRClients::RegisterClient - registering add-on 'NextPVR PVR Client'
00:12:24 T:1196 DEBUG: PVR - PVR::CPVRClient::Create - creating PVR add-on instance 'NextPVR PVR Client'
00:12:24 T:1196 DEBUG: ADDON: Dll Initializing - NextPVR PVR Client
00:12:24 T:1196 DEBUG: LoadLibraryExA called with flags:
00:12:24 T:1196 DEBUG: Previous line repeats 1 times.
00:12:24 T:1196 INFO: AddOnLog: NextPVR PVR Client: Creating NextPVR PVR-Client
00:12:24 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'host'
00:12:24 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'port'
00:12:24 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'pin'
00:12:24 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'usetimeshift'
00:12:24 T:1196 DEBUG: AddOnLog: NextPVR PVR Client: settings: host='192.168.1.112', port=8866
00:12:24 T:1196 DEBUG: CFileCache::Open - opening <service> using cache
00:12:24 T:1196 DEBUG: CurlFile::Open(00F491B8) http://192.168.1.112:8866/service?method...evice=xbmc
00:12:29 T:3572 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
00:12:34 T:1196 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
00:12:34 T:1196 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:12:34 T:1196 ERROR: XFILE::CFileCache::Open - failed to open source <http://192.168.1.112:8866/service?method=session.initiate&ver=1.0&device=xbmc>
00:12:34 T:1196 DEBUG: AddOnLog: NextPVR PVR Client: ->~cPVRClientNextPVR()
00:12:34 T:1196 ERROR: ADDON: Dll NextPVR PVR Client - Client returned bad status (1) from Create and is not usable
00:12:34 T:1196 INFO: Called Add-on status handler for '1' of clientName:NextPVR PVR Client, clientID:pvr.nextpvr (same Thread=no)
00:12:34 T:1196 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on NextPVR PVR Client, status = 1
00:12:34 T:8980 NOTICE: Thread CAddonStatusHandler:pvr.nextpvr start, auto delete: true
00:12:34 T:8980 DEBUG: Thread CAddonStatusHandler:pvr.nextpvr 8980 terminating (autodelete)
00:12:34 T:3572 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
00:12:35 T:1196 DEBUG: PVR::CPVRClients::RegisterClient - registering add-on 'NextPVR PVR Client'
00:12:35 T:1196 DEBUG: PVR - PVR::CPVRClient::Create - creating PVR add-on instance 'NextPVR PVR Client'
00:12:35 T:1196 DEBUG: ADDON: Dll Initializing - NextPVR PVR Client
00:12:35 T:1196 DEBUG: LoadLibraryExA called with flags:
00:12:35 T:1196 DEBUG: Previous line repeats 1 times.
00:12:35 T:1196 INFO: AddOnLog: NextPVR PVR Client: Creating NextPVR PVR-Client
00:12:35 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'host'
00:12:35 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'port'
00:12:35 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'pin'
00:12:35 T:1196 DEBUG: CAddonCallbacksAddon - ADDON::CAddonCallbacksAddon::GetAddonSetting - add-on 'NextPVR PVR Client' requests setting 'usetimeshift'
00:12:35 T:1196 DEBUG: AddOnLog: NextPVR PVR Client: settings: host='192.168.1.112', port=8866
00:12:35 T:1196 DEBUG: CFileCache::Open - opening <service> using cache
00:12:35 T:1196 DEBUG: CurlFile::Open(09273A18) http://192.168.1.112:8866/service?method...evice=xbmc
00:12:38 T:3572 DEBUG: Keyboard: scancode: 1f, sym: 0073, unicode: 0073, modifier: 0
00:12:38 T:3572 DEBUG: CApplication::OnKey: s (f053) pressed, action is ActivateWindow(shutdownmenu)
00:12:38 T:3572 DEBUG: Activating window ID: 10111
00:12:38 T:3572 DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
00:12:38 T:3572 INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
00:12:38 T:3572 DEBUG: CApplication::ExecuteXBMCAction : Translating down
00:12:38 T:3572 DEBUG: CApplication::ExecuteXBMCAction : To down
00:12:38 T:3572 DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
00:12:38 T:3572 DEBUG: CApplication::OnKey: down (f081) pressed, action is Down
00:12:39 T:3572 DEBUG: Keyboard: scancode: 50, sym: 0112, unicode: 0000, modifier: 0
00:12:39 T:3572 DEBUG: CApplication::OnKey: down (f081) pressed, action is Down
00:12:39 T:3572 DEBUG: Keyboard: scancode: 48, sym: 0111, unicode: 0000, modifier: 0
00:12:39 T:3572 DEBUG: CApplication::OnKey: up (f080) pressed, action is Up
00:12:40 T:3572 DEBUG: Keyboard: scancode: 48, sym: 0111, unicode: 0000, modifier: 0
00:12:40 T:3572 DEBUG: CApplication::OnKey: up (f080) pressed, action is Up
00:12:40 T:3572 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
00:12:40 T:3572 DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 000d, modifier: 0
00:12:40 T:3572 DEBUG: CApplication::OnKey: return (f00d) pressed, action is Select
00:12:40 T:3572 DEBUG: CApplication::ExecuteXBMCAction : Translating XBMC.Quit()
00:12:40 T:3572 DEBUG: CApplication::ExecuteXBMCAction : To XBMC.Quit()
00:12:40 T:3572 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
00:12:40 T:3572 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
00:12:40 T:7984 DEBUG: Thread Jobworker 7984 terminating (autodelete)
00:12:40 T:8480 DEBUG: Thread Jobworker 8480 terminating (autodelete)
00:12:40 T:3572 NOTICE: Storing total System Uptime
00:12:40 T:3572 NOTICE: Saving settings
00:12:40 T:3572 NOTICE: stop all
00:12:40 T:3572 INFO: stopping PVRManager
00:12:40 T:9920 DEBUG: EPG - EPG::CEpgContainer:Tonguerocess - pvr manager failed to load - exiting
00:12:40 T:9920 DEBUG: Thread EPG updater 9920 terminating
00:12:40 T:3572 NOTICE: PVRManager - stopping
00:12:40 T:9356 DEBUG: Thread PVR manager 9356 terminating
00:12:45 T:1196 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
00:12:45 T:1196 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
00:12:45 T:1196 ERROR: XFILE::CFileCache::Open - failed to open source <http://192.168.1.112:8866/service?method=session.initiate&ver=1.0&device=xbmc>
00:12:45 T:1196 DEBUG: AddOnLog: NextPVR PVR Client: ->~cPVRClientNextPVR()
00:12:45 T:1196 ERROR: ADDON: Dll NextPVR PVR Client - Client returned bad status (1) from Create and is not usable
00:12:45 T:1196 INFO: Called Add-on status handler for '1' of clientName:NextPVR PVR Client, clientID:pvr.nextpvr (same Thread=no)
00:12:45 T:1196 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on NextPVR PVR Client, status = 1
00:12:45 T:1196 DEBUG: Thread PVR add-on updater 1196 terminating
00:12:45 T:3572 DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
00:12:45 T:3572 NOTICE: ES: Stopping event server
00:12:45 T:3572 DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
00:12:45 T:3572 NOTICE: stopping zeroconf publishing
00:12:45 T:9588 NOTICE: Thread CAddonStatusHandler:pvr.nextpvr start, auto delete: true
00:12:45 T:9588 DEBUG: Thread CAddonStatusHandler:pvr.nextpvr 9588 terminating (autodelete)
00:12:46 T:9380 NOTICE: ES: UDP Event server stopped
00:12:46 T:9380 DEBUG: Thread CEventServer 9380 terminating
00:12:46 T:7364 DEBUG: Thread CTCPServer 7364 terminating
00:12:46 T:6980 DEBUG: Thread XBMC Peripherals 6980 terminating
00:12:46 T:6028 DEBUG: Thread XBMC Peripherals 6028 terminating
00:12:46 T:3572 NOTICE: stop sap announcement listener
00:12:46 T:3572 NOTICE: clean cached files!
00:12:46 T:3572 NOTICE: unload skin
00:12:46 T:3572 INFO: Unloading old skin ...
00:12:46 T:3572 DEBUG: ------ Window Deinit () ------
00:12:46 T:3572 DEBUG: ------ Window Deinit (Home.xml) ------
00:12:46 T:3572 DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
00:12:46 T:3572 DEBUG: ADDON: Stopping service addons.
00:12:46 T:3572 NOTICE: stop python
00:12:46 T:1700 DEBUG: Thread CSoftAE 1700 terminating
00:12:46 T:3572 DEBUG: CAESinkDirectSound:Big Grineinitialize: Cleaning up
00:12:46 T:3572 NOTICE: stopped
00:12:46 T:3572 NOTICE: destroy
Sikriffs;456585 Wrote:I was using Mediaportal TVserver before and have recently switched to Nextpvr. I keep getting "NEXTPVR pvr client connection lost" on all my xbmc client machines except to local pc that NextPvr server is on.
Since it's working from the local machine, but not remote ones, it sounds like your firewall software on your backend PC is not allowing connections through the network from XBMC.
