Full Version: White Mini XBOX 360 DVD Remote Working?
Hi
I've just got OpenElec 3 working on my Foxconn NT330i
Loving XMBC!
I'm currently using a Xbox 1 DVD dongle, adapter cable, and original black Xbox1 DVD remote, which worked fine
So great guns so far!
Now I've taken a fancy to the XBOX360 DVD remote here :
www.amazon.co.uk/dp/B005EVUBY0
With the same setup this doesn't seam to work, yet the Xbox360 remote is mentioned in the lirc.conf file so I'm assuming it should?
Has anyone got this going? If so how?
For what it's worth when I run irw on the command line the original black xbox remote causes codes to appear when keys are pressed but the 360 remote does nothing.
I also have (yes I went on an ebay spree!) the following remote, which comes with a IR USB device, but I'm not sure how to configure that, or if the IR receiver can be used in conjunction with the 360 remote (which I think I prefer out of all three)
www.amazon.co.uk/dp/B003TKJE9G
I have searched the forum for similar problems, and googled about, but there doesn't seam any clear answer (or at least I can't find one)
If anyone who has got this working can help, then please let me know as I would really appreciate it!
