2005-11-17, 08:51
i have a problem that i don't know how to solve. when entering xbmc from evox, the first page that displays is *not* the main menu, instead, it is the browser menu which you see after selecting any from the 4 selections on the main menu. that makes me having to press back to go back to main menu every single time.
this problem only appear when i use 720p as output, 480p does not have this problem... i took a look at the [720p] folder and only seeing fonts.xml which is identical as all fonts.xml in other folders.
could any one tell me where the "homepage" info is saved, so i can modify that?
