I don't know much, but I am trying to learn. Should I use a VPN while using XBMC? I have purchased a service, but I am not sure I should run it with XBMC. Also, can XBMC be configured to connect to a VPN on its own separate from other Internet activities?
I have no idea why you would want to use a VPN with XBMC.
Ofcourse it is possible use a VPN connection with XBMC, but I am not sure what you would like to accomplish.
It is not possible to configure a VPN from within XBMC, this needs to be done form the underlying OS.
Could you explain how you want to use XBMC and why you think a VPN fits in that picture ?
VPN configuration would only be used to talk from one site to another over a WAN no point on a LAN in this environment, The only reason I would think of using a VPN would be to access xbmc library remotely and securely. Main issue with most streaming video remotely is bandwidth intensive and general household users only get 1mb upload speeds.
XbmcMIke
XbmcSkygo Creator
Senior Network Specialist
