Full Version: upgrade problem....
when upgrading from xbmc 11 to 12 my xbmc went crazy, i couldnt uninstall properly, (cant remember the problem code)
after tryin to uninstall and re install i still have this problem
i think i cleared the registry (went into the regedit, software and deleted the xbmc folder)
reboot and reinstalled 12.1
still have the above problem, any ideas how to sort this without a full windows reinstall ??
thanks
Tim.
Update graphics drivers.
hi there, thanks for your reply, according to AMD Driver Autodetect i have the latest driver installed.
anything else to tryHuh
thanks
If you cant upgrade, downgrade the driver, right?
uNi
thanks everyone
thanks Kibje running in xp mode got the job done.
ta guys Smile
Huh, I though AMD had pushed an update for that, but maybe it wasn't for all models.
