Full Version: Frodo: prefer local posters/fanart
Hello,
I have a harddrive full of my movies with proper filenames on my NAS, and I want XBMC to use the local images for my library instead of the scraped URLs in the nfo-files.
Right now, it downloads and caches the URLs from the scraper (IMDB etc.) instead of using my already downloaded posters/fanart.
Here's what it looks like on my NAS:
Here's what the MySQL database looks like after refreshing the library:
I'm using XBMC 12.0RC3. Anybody knows how to use the locally saved images?
EDIT: I also just realized that there is no option to manually choose the local image in the context menu.
http://www.abload.de/img/screenshot000l1q30.png
EDIT2: TV series have no images at all, unfortunately.
Why do your NFO files reference remote artwork if you have them locally? Sounds like your NFOs are wrong - remove the remote artwork references from the NFOs and XBMC will then find the artwork locally.
And why are you using RC3?
