Full Version: xvdr - radio does not play
Hi there - in the german forum for the VDR i already reported this issue.
I use xbmc-frodo 12.1 xvdr and xbmc-addon-xvdr from latest git-repos. The backend (VDR) switches the channel properly:
Mar 27 08:14:10 xbmc0 vdr: [4934] cLiveStreamer stream processor thread ended (pid=3085, tid=4934)
Mar 27 08:14:12 xbmc0 vdr: [4931] XVDR: LiveQueue stopped
Mar 27 08:14:12 xbmc0 vdr: [4899] buffer stats: 5076 (0%) used
Mar 27 08:14:12 xbmc0 vdr: [4899] XVDR: --------------------------------------
Mar 27 08:14:12 xbmc0 vdr: [4899] XVDR: Channel streaming request: 153 - SWR3
Mar 27 08:14:12 xbmc0 vdr: [4899] XVDR: Found available device 2
Mar 27 08:14:12 xbmc0 vdr: [4899] XVDR: Channel information found in cache
Mar 27 08:14:12 xbmc0 vdr: [4899] XVDR: Stream: MPEG2AUDIO PID: 1031 0 Hz, 0 channels, Lang: deu (parsed: no)
Mar 27 08:14:12 xbmc0 vdr: [4937] XVDR: LiveQueue started
Mar 27 08:14:12 xbmc0 vdr: [4933] TS buffer on device 2 thread ended (pid=3085, tid=4933)
Mar 27 08:14:12 xbmc0 vdr: [4932] buffer stats: 4700 (0%) used
Mar 27 08:14:12 xbmc0 vdr: [4932] receiver on device 2 thread ended (pid=3085, tid=4932)
Mar 27 08:14:12 xbmc0 vdr: [4938] receiver on device 2 thread started (pid=3085, tid=4938, prio=high)
Mar 27 08:14:12 xbmc0 vdr: [4899] XVDR: Successfully switched to channel 153 - SWR3
Mar 27 08:14:12 xbmc0 vdr: [4899] XVDR: Started streaming of channel SWR3 (timeout 3 seconds, priority 50)
Mar 27 08:14:12 xbmc0 vdr: [4939] cLiveStreamer stream processor thread started (pid=3085, tid=4939, prio=high)
Mar 27 08:14:12 xbmc0 vdr: [4940] TS buffer on device 2 thread started (pid=3085, tid=4940, prio=high)
Mar 27 08:14:12 xbmc0 vdr: [4939] XVDR: --------------------------------------
Mar 27 08:14:12 xbmc0 vdr: [4939] XVDR: NEW AUDIO INFORMATION:
Mar 27 08:14:12 xbmc0 vdr: [4939] XVDR: Channels: 2
Mar 27 08:14:12 xbmc0 vdr: [4939] XVDR: Samplerate: 48000 Hz
Mar 27 08:14:12 xbmc0 vdr: [4939] XVDR: Bitrate: 320000 bps
Mar 27 08:14:17 xbmc0 vdr: [3213] frontend 0/0 timed out while tuning to channel 171, tp 211131
Mar 27 08:14:38 xbmc0 vdr: [3213] frontend 0/0 timed out while tuning to channel 168, tp 212558
Mar 27 08:14:48 xbmc0 vdr: EPG2VDR: Handle update of event 11270 [11270S19.2E-1-
but xbmc does not play at all.
Investigating this further yesterday on the xbmc-side showed this to me (also looks normal to me):
09:46:02 T:140332489250752   DEBUG: OnKey: 11 (0b) pressed, action is Select
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers(pvr://channels/radio/Alle Radio-Kanäle/9.pvr)
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: radio
09:46:02 T:140332489250752   DEBUG: CPlayerSelectionRule::GetPlayers: adding player: DVDPlayer (1) for rule: radio
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers: matched 1 rules with players
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
09:46:02 T:140332489250752   DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
09:46:02 T:140332489250752  NOTICE: DVDPlayer: Opening: pvr://channels/radio/Alle Radio-Kanäle/9.pvr
09:46:02 T:140332489250752 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
09:46:02 T:140332489250752   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
09:46:02 T:140332489250752   DEBUG: LinuxRendererGL: Cleaning up GL resources
09:46:02 T:140332489250752   DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16
09:46:02 T:140332362880768  NOTICE: Thread CDVDPlayer start, auto delete: false
09:46:02 T:140332362880768  NOTICE: Creating InputStream
09:46:02 T:140332362880768   DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'BAYERN 3'
09:46:02 T:140332362880768   DEBUG: opening live stream for channel 'BAYERN 3'
09:46:02 T:140332362880768   DEBUG: AddOnLog: VDR XVDR Client: Possible leak caused by workaround in GetLanguageCode
09:46:02 T:140332362880768    INFO: AddOnLog: VDR XVDR Client: Logged in at '1366530362+7200' to 'VDR-XVDR Server' Version: '0.9.9' with protocol version '5'
09:46:02 T:140332362880768    INFO: AddOnLog: VDR XVDR Client: Preferred Audio Language: deu
09:46:02 T:140332362880768   DEBUG: AddOnLog: VDR XVDR Client: changing to channel 134327167 (priority 50)
09:46:02 T:140332362880768    INFO: AddOnLog: VDR XVDR Client: sucessfully switched channel
09:46:02 T:140332362880768   DEBUG: Mysql execute: REPLACE INTO channels (iUniqueId, bIsRadio, bIsHidden, bIsUserSetIcon, bIsLocked, sIconPath, sChannelName, bIsVirtual, bEPGEnabled, sEPGScraper, iLastWatched, iClientId, iClientChannelNumber, sInputFormat, sStreamURL, iEncryptionSystem, idChannel, idEpg) VALUES (134327167, 1, 0, 0, 0, 'http://amun.thielemann.intern/ocram-picons/picons-hd-reflection/1_0_2_6EF2_445_1_C00000_0_0_0.png', 'BAYERN 3', 0, 1, 'client', 1366537562, 1, 155, '', '', 0, 10, 41213)
09:46:02 T:140332362880768   DEBUG: PVRFile - Open - playback has started on filename pvr://channels/radio/Alle Radio-Kanäle/9.pvr
09:46:02 T:140332362880768   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/radio/Alle Radio-Kanäle/9.pvr
09:46:02 T:140332362880768  NOTICE: Creating Demuxer
09:46:02 T:140332362880768   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcodec-53-x86_64-linux.so)
09:46:02 T:140332362880768   DEBUG: Loading: /usr/local/lib/xbmc/system/players/dvdplayer/avcodec-53-x86_64-linux.so
09:46:02 T:140332362880768   DEBUG: CDVDPlayer::SetCaching - caching state 2
09:46:02 T:140332362880768 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
09:46:02 T:140332362880768 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
09:46:02 T:140332489250752   DEBUG: ------ Window Init (DialogSeekBar.xml) ------
09:46:02 T:140332489250752   DEBUG: Window DialogSeekBar.xml was already loaded
09:46:02 T:140332489250752   DEBUG: Alloc resources: 0.55m
09:46:02 T:140332489250752   DEBUG: CGUIInfoManager::SetCurrentSong(pvr://channels/radio/Alle Radio-Kanäle/9.pvr)
09:46:02 T:140332489250752   DEBUG: Loading additional tag info for file pvr://channels/radio/Alle Radio-Kanäle/9.pvr
09:46:02 T:140332489250752   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
09:46:02 T:140332489250752   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
09:46:08 T:140332489250752   DEBUG: LIRC: Update - NEW at 1411395:80 0 KEY_STOP /dev/input/irremote0 (KEY_STOP)
09:46:08 T:140332489250752   DEBUG: OnKey: 224 (e0) pressed, action is Stop
09:46:08 T:140332489250752  NOTICE: CDVDPlayer::CloseFile()
09:46:08 T:140332489250752  NOTICE: DVDPlayer: waiting for threads to exit
09:46:08 T:140332362880768  NOTICE: CDVDPlayer::OnExit()
09:46:08 T:140332362880768   DEBUG: CDVDPlayer::SetCaching - caching state 0
09:46:08 T:140332362880768  NOTICE: CDVDPlayer::OnExit() deleting demuxer
09:46:08 T:140332362880768  NOTICE: CDVDPlayer::OnExit() deleting input stream
09:46:08 T:140332362880768   DEBUG: Mysql execute: REPLACE INTO channels (iUniqueId, bIsRadio, bIsHidden, bIsUserSetIcon, bIsLocked, sIconPath, sChannelName, bIsVirtual, bEPGEnabled, sEPGScraper, iLastWatched, iClientId, iClientChannelNumber, sInputFormat, sStreamURL, iEncryptionSystem, idChannel, idEpg) VALUES (134327167, 1, 0, 0, 0, 'http://amun.thielemann.intern/ocram-picons/picons-hd-reflection/1_0_2_6EF2_445_1_C00000_0_0_0.png', 'BAYERN 3', 0, 1, 'client', 1366537568, 1, 155, '', '', 0, 10, 41213)
09:46:08 T:140332362880768   DEBUG: CDVDInputStreamPVRManager::Close - stream closed
09:46:08 T:140332362880768   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
09:46:08 T:140332362880768   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
09:46:08 T:140332362880768   DEBUG: Thread CDVDPlayer 140332362880768 terminating
09:46:08 T:140332489250752  NOTICE: DVDPlayer: finished waiting
09:46:08 T:140332489250752   DEBUG: LinuxRendererGL: Cleaning up GL resources
09:46:08 T:140332489250752 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
How can i investigate further?
wrong forum, no xvdr support here
vnsi only?
by "law" or because of what? (excuse my stupid question)
Only experience. Absolutely no problem posting xvdr questions here but the probability for educated answers is low.
moved to vnsi, frodo12.2. radio now works fine
