2013-04-22, 20:37
I've issue with vaapi. When i enable it, some of HD channels in Live TV freeze. Debug says:
i think, that is some problem with vaapiwhen i disable vaapi accelerate in settigh, problem channels work but cpu is overloaded and picture is like 10-15fps :/
some info about system and hardware:
ZOTAC NANO AD10
does anyone have any idea how to fix it?
20:27:52 T:139846827104000 DEBUG: Output Device : HD-Audio Generic
20:27:52 T:139846827104000 DEBUG: Sample Rate : 48000
20:27:52 T:139846827104000 DEBUG: Sample Format : AE_FMT_S16NE
20:27:52 T:139846827104000 DEBUG: Channel Count : 2
20:27:52 T:139846827104000 DEBUG: Channel Layout: FL,FR
20:27:52 T:139846827104000 DEBUG: Frames : 2400
20:27:52 T:139846827104000 DEBUG: Frame Samples : 4800
20:27:52 T:139846827104000 DEBUG: Frame Size : 4
20:27:52 T:139846827104000 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
20:27:52 T:139846827104000 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 19200
20:27:52 T:139846827104000 DEBUG: AERemap: Downmix normalization is disabled
20:27:52 T:139845435369216 DEBUG: Previous line repeats 3 times.
20:27:52 T:139845435369216 DEBUG: CDVDPlayerAudio:: synctype set to 1: skip/duplicate
20:27:52 T:139845583148800 DEBUG: CDVDPlayer::HandleMessages - player started 1
20:27:53 T:139845583148800 DEBUG: set caching from pvr to done. audio (1) = 11. video (1) = 13
20:27:53 T:139845583148800 DEBUG: CDVDPlayer::SetCaching - caching state 0
20:27:53 T:139845435369216 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:610.244000, should be:-262676.474667, error:-263286.718667
20:27:53 T:139846827104000 DEBUG: CSoftAE::Run - Sink restart flagged
20:27:53 T:139846827104000 INFO: CSoftAE::LoadSettings - Stereo upmix is enabled
20:27:53 T:139846827104000 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 48000hz
20:27:53 T:139846827104000 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
20:27:53 T:139846827104000 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 19200
20:27:53 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:27:53 T:139847082465152 DEBUG: CLinuxRendererGL::UploadVAAPITexture - creating vaapi surface for texture 0
20:27:55 T:139845404829440 WARNING: Previous line repeats 11 times.
20:27:55 T:139845404829440 ERROR: VAAPI - renderer still using all freed up surfaces by decoder
20:27:55 T:139845404829440 ERROR: VAAPI - unable to find free surface, trying to allocate a new one
20:27:55 T:139845404829440 DEBUG: VAAPI - making sure 8 surfaces are allocated for given 4 references
20:27:55 T:139845404829440 ERROR: VAAPI - failed executing vaCreateContext(m_display->get() , m_config , avctx->width , avctx->height , VA_PROGRESSIVE , m_surfaces , m_surfaces_count , &m_hwaccel->context_id) at line 429 with error 6:invalid VASurfaceID
20:27:55 T:139845404829440 ERROR: Decode - avcodec_decode_video returned failure
20:27:55 T:139845404829440 DEBUG: CDVDPlayerVideo - video decoder returned error
20:27:55 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:27:56 T:139845435369216 ERROR: Previous line repeats 3 times.
20:27:56 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:27:56 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:27:56 T:139845435369216 ERROR: Previous line repeats 2 times.
20:27:56 T:139845435369216 ERROR: Previous line repeats 1 times.
20:27:57 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:27:57 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:27:57 T:139845435369216 ERROR: Previous line repeats 3 times.
20:27:57 T:139845435369216 ERROR: Previous line repeats 2 times.
20:27:57 T:139845435369216 ERROR: Previous line repeats 5 times.
20:27:57 T:139845435369216 ERROR: Previous line repeats 1 times.
20:27:58 T:139845435369216 ERROR: Previous line repeats 6 times.
20:27:58 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:27:58 T:139847082465152 WARNING: Previous line repeats 1 times.
20:27:58 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:27:58 T:139845435369216 ERROR: Previous line repeats 2 times.
20:27:58 T:139845435369216 ERROR: Previous line repeats 1 times.
20:27:58 T:139845435369216 ERROR: Previous line repeats 3 times.
20:27:58 T:139845435369216 ERROR: Previous line repeats 8 times.
20:27:59 T:139845435369216 ERROR: Previous line repeats 2 times.
20:27:59 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:27:59 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:27:59 T:139845435369216 ERROR: Previous line repeats 3 times.
20:27:59 T:139845435369216 ERROR: Previous line repeats 1 times.
20:27:59 T:139845435369216 ERROR: Previous line repeats 5 times.
20:28:00 T:139845435369216 ERROR: Previous line repeats 1 times.
20:28:00 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:28:00 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:28:00 T:139845435369216 ERROR: Previous line repeats 2 times.
20:28:00 T:139845435369216 ERROR: Previous line repeats 4 times.
20:28:01 T:139845404829440 ERROR: Previous line repeats 5 times.
20:28:01 T:139845404829440 DEBUG: CPullupCorrection: detected pattern of length 1: 40000.00, frameduration: 40000.000000
20:28:01 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:28:01 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:28:01 T:139845435369216 ERROR: Previous line repeats 1 times.
20:28:01 T:139845435369216 ERROR: Previous line repeats 5 times.
20:28:01 T:139845435369216 ERROR: Previous line repeats 3 times.
20:28:01 T:139845435369216 ERROR: Previous line repeats 2 times.
20:28:02 T:139845435369216 ERROR: Previous line repeats 1 times.
20:28:02 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:28:02 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:28:02 T:139845435369216 ERROR: Previous line repeats 2 times.
20:28:02 T:139845435369216 ERROR: Previous line repeats 3 times.
20:28:03 T:139845435369216 ERROR: Previous line repeats 1 times.
20:28:03 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:28:03 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:28:03 T:139845435369216 ERROR: Previous line repeats 2 times.
20:28:03 T:139845435369216 ERROR: Previous line repeats 8 times.
20:28:04 T:139845435369216 ERROR: Previous line repeats 2 times.
20:28:04 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:28:04 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:28:04 T:139845435369216 ERROR: Previous line repeats 4 times.
20:28:04 T:139845435369216 ERROR: Previous line repeats 3 times.
20:28:04 T:139845435369216 ERROR: Previous line repeats 1 times.
20:28:05 T:139845435369216 ERROR: Previous line repeats 7 times.
20:28:05 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:28:05 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
20:28:05 T:139845435369216 ERROR: Previous line repeats 2 times.
20:28:05 T:139845435369216 ERROR: Previous line repeats 4 times.
20:28:05 T:139845435369216 ERROR: Previous line repeats 3 times.
20:28:06 T:139845435369216 ERROR: Previous line repeats 1 times.
20:28:06 T:139845435369216 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:28:06 T:139847082465152 ERROR: CLinuxRendererGL::UploadVAAPITexture - failed to copy surface to glx 5 - invalid VAContextID
xbmc@zotac:~$ uname -a
Linux zotac 3.5.0-27-generic #46-Ubuntu SMP Mon Mar 25 19:58:17 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
xbmc@zotac:~$ cat /proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 20
model : 1
model name : AMD E-350 Processor
stepping : 0
microcode : 0x5000028
cpu MHz : 800.000
cache size : 512 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 6
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm constant_tsc rep_good nopl nonstop_tsc extd_apicid aperfmperf pni monitor ssse3 cx16 popcnt lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch ibs skinit wdt arat hw_pstate npt lbrv svm_lock nrip_save pausefilter
bogomips : 3200.09
TLB size : 1024 4K pages
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management: ts ttp tm stc 100mhzsteps hwpstate
processor : 1
cpu family : 20
model : 1
stepping : 0
cpu MHz : 800.000
cache size : 512 KB
physical id : 0
siblings : 2
core id : 1
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 6
wp : yes
bogomips : 3200.09
clflush size : 64
