2013-04-24, 21:49
2013-04-24, 22:03
Logos should be always on during playback and work for tvshows and movies yes?
Then with a good text editor like Notepad++ add the following code to the following files.
DialogSeekbar.xml
Variables.xml
DialogSeekbar.xml
<control type="image">
<posx>250r</posx>
<posy>25</posy>
<width>190</width>
<height>90</height>
<texture>$VAR[Now_Playing_Logo]</texture>
<aspectratio>keep</aspectratio>
</control>
Variables.xml
<variable name="Now_Playing_Logo">
<value condition="VideoPlayer.Content(movies)">$INFO[Player.Art(clearlogo)]</value>
<value condition="VideoPlayer.Content(episodes)">$INFO[Player.Art(tvshow.clearlogo)]</value>
</variable>
2013-06-14, 19:59
Hi, I added the above code to the xml files, but nothing shows when playing, only when paused.I am using Aeon Nox. Any help would be grateful
2013-06-15, 20:49
In Nox, line number 4 (before the controls start) has visible conditions that prevent it showing up.
You need the image unaffected by these. To do that you have to regroup the rest. You could do something like this:
And then you also need an extra closing tag all the way in the bottom
I didn't test, but it should work.
<?xml version="1.0" encoding="utf-8"?>
<window>
<defaultcontrol>1</defaultcontrol>
<coordinates>
<system>1</system>
<posx>0</posx>
<posy>0</posy>
</coordinates>
<controls>
<posx>250r</posx>
<posy>25</posy>
<width>190</width>
<height>90</height>
</control>
<control type="group">
<visible>[Player.Seeking | Player.DisplayAfterSeek | Player.Paused | Player.Forwarding | Player.Rewinding] + ![VideoPlayer.Content(livetv) | Window.IsVisible(videoosd) | Window.IsVisible(fullscreeninfo) | Window.IsActive(script-XBMC-Subtitles-main.xml)] + Window.IsVisible(fullscreenvideo)</visible>
<visible>!Skin.HasSetting(Show_Info_Paused)</visible>
<include>FullScreenInfoBar</include>
</control>
</control>
<include>AlaskaPausedLabel</include>
</control>
</controls>
</window>
2013-06-15, 22:31
Hi MassIV, Thank you for your help
but alas I entered the above code and it did not work
2013-06-16, 12:57
Tested, works just fine.
http://pastebin.com/FyYJJCFR
And don't forget you still need to add the variable to Variables.xml
But i saw nox already had a logo on pause. So i added that the one showing while playing does not show when paused.
If you want to see both while paused remove line 19
<visible>!Player.Paused</visible>
