Full Version: Fanart wrap
Hi all
Just updated to Frodo and latest Back Row SVN
one small problem I can not get the Fanart Wrap view option in movies, only list views, Im not using Movies Library but linking it to straight to my movies folder as I have all my movies in genres folders on the HDD
cheers for any help
Hi
Ok I think to get that view you need to set the content type for your movies folder to "movies" - you don't need to scan them into the library but unless you set the content you'll only get the default file mode views.
Thanks Sharpe
yep I've got folder set to movies.
Its only showing the file list of my folders eg Action, Horror, Sci-fi eta, when I go into each folder I can the get Fanart Wrap of it contents.
its not the end of the world but I liked the Fanart view I could get before the upgrade to Frodo.
Cheers Borg101
