2013-06-06, 22:23
I haven't noticed anything using latest GIT version. It's staying stable around 70%.
I believe I never had my openelec Pi at 15% (not even at 40%)... lol
23:04:25 T:3041579648 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
23:04:25 T:3041579648 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
(2013-06-06, 21:54)miappa Wrote: [ -> ]Something is really wrong with latest git version, or something went wrong in my setup.I'm ok with 0.3.3.
CPU on Pi is close to 100% all the time, even on very calm screens where before CPU was at ≈ 15%.
This makes it really slow and pretty much unusable.
Changed to Confluence which behaved normal, tried another light skin which also behaved normal.
I will try to remove guisettings.xml and reinstall the skin and see if it persists (if the install went bad).
Will report back.
Edit: I couldn´t get it to work and unfortunately I did not save the old version, so at the moment I am off Amber.
Anyone lese seeing this or is it something wrong with my Pi or setup?
00:00:52 T:140735239487872 DEBUG: Window DialogExtendedProgressBar.xml was already loaded
00:00:52 T:140735239487872 DEBUG: Alloc resources: 3.23m
00:00:52 T:140735239487872 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
00:00:52 T:140735239487872 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
00:00:52 T:140735239487872 DEBUG: Alloc resources: 2.55m
00:00:52 T:140735239487872 DEBUG: Alloc resources: 2.25m
(2013-06-07, 00:04)miappa Wrote: [ -> ]As some people seems to not have this issue I tried it on OSX and ATV2 with same result.
Same message repeating over and over again.
From OSX:
Code:00:00:52 T:140735239487872 DEBUG: Window DialogExtendedProgressBar.xml was already loaded
Let me know if you´ll need anything else.
(2013-06-06, 22:46)miappa Wrote: [ -> ]Using Raspbmc and have tested 12.2 stable and 13.0alpha.
Same problem on both so I am quite certain something has changed in latest Amber as other skins still works as they should.
I can test this on my ATV2 as well and report back.
@lysin
I usually have ≈15-20%CPU on home screen, but I have even lower on my OpenELEC version, ≈10-15% (have an extra SD with OpenELEC for testing purposes).
I test OpenELEC every now and then and I have same low CPU% on both rbej´s custom builds and standard releases.
If you have something moving (scrolling text etc) or a lot of text on the screen CPU spikes directly (calm screen = nothing moving and very little text).
Maybe you have some addons that causes that high CPU usage, or other background processes.
Low CPU in GUI means WAY snappier, Amber usually is has the lowest numbers I have tested and therefor the fastest skin (confluence is pretty much the same though).
Difference between Confluence and Amber can be seen in pictures below (before it was pretty much no difference):
https://www.dropbox.com/s/k0nhgsj7nq0pk96/amber.jpg
https://www.dropbox.com/s/25rzg7rquivwnb...luence.jpg
(2013-06-06, 23:04)relyter Wrote: [ -> ]I'm ok with 0.3.3.
pecinko
- All picture view modes except panel lost black transparent bg
- big list in video/music/pictures addons is not really big
- on home screen when focus is on the weather you can see only 3 titles on ribbon instead of 5
(2013-06-09, 14:18)pecinko Wrote: [ -> ]Home menu looks will vary depending of label length, thats not a bugVery good, no scrolling text on home screen -> less CPU%.And with latest fixes in place my CPU is below 10% Thanks for testing.
(2013-06-09, 14:18)pecinko Wrote: [ -> ]BTW Original question remains unanswered - what about missing seekbar labels on some of RPi installs, it that fixed now?Sorry, never had this problem and it still works for me (which is good of course, but I cannot confirm...).
(2013-06-09, 14:18)pecinko Wrote: [ -> ]I have removed BigList for now - I'm not happy with current looks so it's out until I rework it.I use the big list only in addons (video) as it is the only list view that shows content info (at least in SVTPlay addon). Not a biggie, I just use panel instead for now, not as snappy but works good.
