Full Version: Archive - old posts
OK, I think I have found a way to solve widgets problems. I need to think a bit about how to implement it.
pecinko is there anything I can do for my issue please?
(2013-08-19, 15:39)UnStable Wrote: [ -> ]pecinko is there anything I can do for my issue please?
Everybody got an answer but you? Sorry, I'm still considering possibilities. I have re-worked controls and my kids are happy with it. I'm not sure I can easily maintain horizontal controls as an option.
Ahhh... ok sorry I didn't realise this new layout was working as intended I thought I had occidentally toggled something. I can live with it if that's the case Smile
Thanks for all your hard work on this skin.
(2013-08-19, 15:46)pecinko Wrote: [ -> ]
I'm not your kid, but i'm also happy with new OSD. Smile Probably it could be not so wide, but it still very good.
+1 of the OSD I think it's very nice
(2013-08-14, 19:52)pecinko Wrote: [ -> ]
(2013-08-14, 12:59)abcabc Wrote: [ -> ]So now would be a good time to move the total movie/shows/ep. breadcrumbs to the top left corner?
On a second thought I might do just that. Thanks!
Nice, thank you! Smile
I guess I'm the only one who liked the horizontal OSD better.. Blush
I like the horizontal skin too, so I'm all for horizontal views.
Is there no little little chance to get this as an option, please? Angel
I am having some troubles making use of the edit playlist dialog.
See for a printscreen the next link.
http://www.sendspace.com/file/dhd85c
In Amber it's very difficult to click OK. It can't be done with the arrowkeys.
I did also include the dialog from the standard skin.
(2013-08-19, 18:49)hstegeman Wrote: [ -> ]I am having some troubles making use of the edit playlist dialog.
Friends don't make friends use stupid webs.
Please, use Imgur or Dropbox or something similar to post screens. Both are free.
EDIT: Should be fixed on Git.
(2013-08-19, 19:47)pecinko Wrote: [ -> ]
I found a bug in this update.
When I chose art for a tv-show's season, the menu is too small.
(2013-08-19, 18:46)abcabc Wrote: [ -> ]I guess I'm the only one who liked the horizontal OSD better.. Blush
Another +1 for the horizontal OSD.
Love the skin though. Thanks for all the hard work.
(2013-08-19, 20:51)abcabc Wrote: [ -> ]I found a bug in this update.
Thanks. Should be fixed.
(2013-08-19, 09:09)Atinkler Wrote: [ -> ]Mad or special. .. it's a thin line. :-) haha haha thanks for the update.
Git version should be able to fix your problem.
pecinko
There's 3 lines of plot in fullscreen video info. It doesn't scroll despite autoscroll is set to Yes in skin settings. Is it suppose this way? And a scrollbar mark in music playlist window goes beyond window border.
(2013-08-14, 22:14)hstegeman Wrote: [ -> ]Post a screenshot, please.
Here is a link to a amber screenshot with List.
http://www.sendspace.com/file/sjrsqz
A link with a confluence screenshot with Big List.
I think the thumbnails are too small.
http://www.sendspace.com/file/m6k17w
[/quote]
Hello pecinko,
Did you look at these screenshots? I didn't read a resonse from you.
Pecinko, thank you very much the dialog is looking oke now.
(2013-08-20, 14:16)relyter Wrote: [ -> ]pecinko
Should be fixed on Git. Please check.
