Full Version: TV Show Banner issue using sync multiple libraries
I have tested this on another skin and seems fine however using Confluence and selecting wide icons and a shared library using MySQL, Confluence seems to get confused and uses the posters rather than banners. I say confused as when I set the library up initially using my Windows 7 PC, the banners appeared without issue. The issue occurred as soon as I sync'd my Raspberry Pi to the same library. Now on both systems and selecting view type "Wide icons", the posters rather than banners appeared.
I switched to ACE skin on Windows PC to see if it was a generic issue rather than skin specific but ACE used the banners. I then switched back to Confluence to see if just be switching skin it would resolve but unfortunately it did not.
I have just noticed that the posters for my movie sets have also disappeared. This is not skin specific as they don't appear under ACE either.
Issue seems to have resolved itself....
