Full Version: On screen info during playback
when i hit the i button on the remote to bring up info about the TV show I'm currently watching there is a section on the left hand side that displays the season and episode number - but it always displays as "Season X/Episode..." as if there is no room on the screen to display the episode number. I'd love it it this could be cleaned up to display the full info. It's not an end of the world feature but I'm a bit OCD about stuff like this!!
Happy to post up a picture later if I've not explained it too well.
thanks in advance for help with this one.
Could you try changing line 234 in 720p/DialogFullScreenVideo.xml to
<label>$LOCALIZE[20359] $INFO[VideoPlayer.Season]x$INFO[VideoPlayer.Episode]</label>
and report back if that works ?
Thanks for the response, have been away from the machine for an extended bank holiday weekend but back now and should be ableto give this a go in the next couple of days. Will get back to you once I've tried.
Worked perfectly, thanks !!
I marked this as solved and split the other post off into a seperate thread.
