Full Version: Adding STRM Files to library.
Hey there , I happen to be in the Position to have all my favorite TV channels in form of an http stream , therefore i'm not relying on the PVR feature.
I would like to add the HTTP Streams to Pseudotv , trying this I had 2 Problems.
For once , the streams Play just fine when opened as m3u file , not so much when opening them as strm files.
The second Problem being is that regardless, I can't seem to add the strm files to the XBMC libary , I did create an NFO file , but nothing. Any help would be awesome.
thanks
I am successfully using TV Guide for my .strm files. Just a thought.
Considered that , decided to stick with Pseudotv , thanks though
u have to use a special scraper to get strm in library go to this http://forum.xbmc.org/showthread.php?tid=160904
