Full Version: Crash Problem on Start - AudioEngine
Hi All,
I am trying to setup XBMC on my 2012 Mac Mini and am hitting a crash on start bug. It seems to be going FATAL on trying to start the AudioEngine?
Any help would be great.
Rage
From my xvmc.log:
20:12:29 T:2885827112 NOTICE: -----------------------------------------------------------------------
20:12:29 T:2885827112 NOTICE: Starting XBMC (12.1 Git:20130317-0d373cc), Platform: Darwin OSX (12.3.0 x86_64, Version 10.8.3 (Build 12D78)). Built on Mar 17 2013
20:12:29 T:2885827112 NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
20:12:29 T:2885827112 NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
20:12:29 T:2885827112 NOTICE: special://masterprofile/ is mapped to: /Users/rage/Library/Application Support/XBMC/userdata
20:12:29 T:2885827112 NOTICE: special://home/ is mapped to: /Users/rage/Library/Application Support/XBMC
20:12:29 T:2885827112 NOTICE: special://temp/ is mapped to: /Users/rage/.xbmc/temp
20:12:29 T:2885827112 NOTICE: special://frameworks/ is mapped to: /Applications/XBMC.app/Contents/Frameworks
20:12:29 T:2885827112 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
20:12:29 T:2885827112 NOTICE: Local hostname: TV-Mini.local
20:12:29 T:2885827112 NOTICE: Log File is located: /Users/rage/Library/Logs/xbmc.log
20:12:29 T:2885827112 NOTICE: load settings...
20:12:29 T:2885827112 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
20:12:29 T:2885827112 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:12:29 T:2885827112 NOTICE: loading special://masterprofile/guisettings.xml
20:12:29 T:2885827112 NOTICE: Getting hardware information now...
20:12:29 T:2885827112 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:12:29 T:2885827112 NOTICE: Loaded playercorefactory configuration
20:12:29 T:2885827112 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:12:29 T:2885827112 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:12:29 T:2885827112 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:12:29 T:2885827112 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:12:29 T:2885827112 NOTICE: Default DVD Player: dvdplayer
20:12:29 T:2885827112 NOTICE: Default Video Player: dvdplayer
20:12:29 T:2885827112 NOTICE: Default Audio Player: paplayer
20:12:29 T:2885827112 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:12:29 T:2885827112 NOTICE: Log level changed to 0
20:12:29 T:2885827112 NOTICE: Loading media sources from special://masterprofile/sources.xml
20:12:29 T:2885827112 ERROR: CCoreAudioDevice::SupportsMixing: Device mixing support : 'No'.
20:12:29 T:2885827112 ERROR: CCoreAudioMixMap::SetMixingMatrix - ouput format doesn't fit mixer size 8 > 16
20:12:29 T:2885827112 FATAL: CApplication::Create: Failed to start the AudioEngine
set audio-midisetup to 2channel and it should startup,again - known issue in 12.1
