2013-04-28, 14:34
Firstly, sorry to not include a log file but this is part of the reason why I'm posting.
I'm getting the following error when I enter my movie folder within XBMC GUI.
Assertion Failed
Program: C:\ Program Files (x86)\ XBMC\ XBMC.exe
File: libavformat/utils.c
Line: 2195
Expressions: s-> chapters [i] -> start < = s - > chapters [ i +1] - > start
Reading some posts in the forum, I see that turning on debugging was requested by some members in order for them to help. I've enabled this within XBMC and repeated the same actions as before and it comes up with the same error and I'm given three options
Abort, Retry, and Ignore
So to debug it mentions to select retry and that JIT needs to be enabled. Firstly can someone enlighten me on what JIT is and how to enable it and what I should be seeing after selecting retry?
What I do see is a windows message saying "XBMC has stopped working" Windows is checking for a solution, It then just gives the option to close the program.
I can't see that any log has been produced, which is rather annoying seeing as many people who posted on this very error seem to have no problem what so ever. Maybe I'm missing something
I did add a large amount of movies recently and a number didn't get recognised when they were automatically scanned with Media Centre Master v2.05. Reading up about this error it appears that it's a problem with getting info from the file itself (Hope I'm correct?) So I wonder if MCM which continually is trying to re scan the movies, is causing the crash because it's using the files and XBMC can't access them??
I really don't know to be honest, and without the log I can't see what the problem is
I'll provide below as much info as I can and if someone is able to point me in the right direction that would be great.
So to sum up, I just want to get XBMC logging this error and a little help sorting the error.
XBMC 11.0 PRE GIT: 20120302- 7885010 (Compiled Mar 2nd 2012)
Aeon MQ3 2.0.1 (SKIN)
MCM v2.05
Windows Home Premium 64bit
16GB Memory
i5 3570k 3.40GHZ
If I can provide anymore information to help things along then please ask
Assertion Failed
Line: 2195
MCM v2.05
16GB Memory
i5 3570k 3.40GHZ
