Full Version: Music Videos not playing
I have OpenElec 3.0 on my raspberry pi with Frodo 12.1. When I try to play a FLV music video (example in log is Jay Sean - Down.flv down at the end of the log), the working (circle turning) box comes up and never goes away. The video never plays and I have to reboot the raspberry pi. I am attaching a log file if it helps to determine my issue.
19:00:26 T:3043655680 NOTICE: -----------------------------------------------------------------------
19:00:27 T:3043655680 NOTICE: Starting XBMC (12.1 Git:0d373cc), Platform: Linux (OpenELEC - Version: 3.0.0, 3.6.11 armv6l). Built on Mar 24 2013
19:00:27 T:3043655680 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
19:00:27 T:3043655680 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
19:00:27 T:3043655680 NOTICE: special://masterprofile/ is mapped to: /storage/.xbmc/userdata
19:00:27 T:3043655680 NOTICE: special://home/ is mapped to: /storage/.xbmc
19:00:27 T:3043655680 NOTICE: special://temp/ is mapped to: /storage/.xbmc/temp
19:00:27 T:3043655680 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
19:00:27 T:3043655680 NOTICE: Local hostname: openelec
19:00:27 T:3043655680 NOTICE: Log File is located: /storage/.xbmc/temp/xbmc.log
19:00:27 T:3043655680 NOTICE: -----------------------------------------------------------------------
19:00:27 T:3043655680 NOTICE: load settings...
19:00:27 T:3043655680 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:00:27 T:3043655680 NOTICE: loading special://masterprofile/guisettings.xml
19:00:27 T:3043655680 NOTICE: Getting hardware information now...
19:00:27 T:3043655680 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:00:28 T:3043655680 NOTICE: Loaded playercorefactory configuration
19:00:28 T:3043655680 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:00:28 T:3043655680 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:00:28 T:3043655680 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
19:00:28 T:3043655680 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<destroywindowcontrols>false</destroywindowcontrols>
<fanartres>540</fanartres>
<imageres>256</imageres>
<bginfoloadermaxthreads>2</bginfoloadermaxthreads>
<useddsfanart>false</useddsfanart>
<video>
<defaultplayer>omxplayer</defaultplayer>
<defaultdvdplayer>omxplayer</defaultdvdplayer>
</video>
<audio>
<streamsilence>false</streamsilence>
</audio>
<network>
<cachemembuffersize>2097152</cachemembuffersize>
</network>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<curlclienttimeout>30</curlclienttimeout>
</network>
</advancedsettings>
19:00:28 T:3043655680 NOTICE: Getting hardware information now...
19:00:28 T:3043655680 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
19:00:28 T:3043655680 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.0.197</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</musicdatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
</videolibrary>
</advancedsettings>
19:00:28 T:3043655680 WARNING: VIDEO database configuration is experimental.
19:00:28 T:3043655680 NOTICE: Default DVD Player: omxplayer
19:00:28 T:3043655680 NOTICE: Default Video Player: omxplayer
19:00:28 T:3043655680 NOTICE: Default Audio Player: omxplayer
19:00:28 T:3043655680 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:00:28 T:3043655680 NOTICE: Log level changed to 0
19:00:28 T:3043655680 NOTICE: Loading media sources from special://masterprofile/sources.xml
19:00:29 T:3043655680 ERROR: Error: Requested setting (audiooutput.guisoundmode) was not found. It must be case-sensitive
19:00:29 T:3043655680 NOTICE: Running database version Addons15
18:39:08 T:3043655680 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
18:39:08 T:3032478816 NOTICE: Thread CEC Adapter start, auto delete: false
18:39:08 T:3021993056 NOTICE: Thread XBMC Peripherals start, auto delete: false
18:39:11 T:3043655680 NOTICE: Previous line repeats 1 times.
18:39:11 T:3043655680 NOTICE: Raspberry PI firmware version: Mar 19 2013 00:02:38
Copyright © 2012 Broadcom
version 377915 (release)
18:39:11 T:3043655680 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
18:39:11 T:3043655680 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
18:39:11 T:3043655680 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
18:39:11 T:3043655680 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
18:39:11 T:3043655680 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 60.000000 Hz
18:39:11 T:3043655680 NOTICE: Found resolution 1280 x 720 for display 0 with 1920 x 1080 @ 24.000000 Hz
18:39:11 T:3043655680 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
18:39:11 T:3043655680 NOTICE: Found resolution 960 x 720 for display 0 with 1024 x 768 @ 60.000000 Hz
18:39:11 T:3043655680 NOTICE: Found resolution 900 x 720 for display 0 with 1280 x 1024 @ 60.000000 Hz
18:39:11 T:3043655680 NOTICE: Found ([email protected]) at 19, setting to RES_DESKTOP at 16
18:39:11 T:3043655680 NOTICE: Checking resolution 16
18:39:11 T:3043655680 NOTICE: GL_VENDOR = Broadcom
18:39:11 T:3043655680 NOTICE: GL_RENDERER = VideoCore IV HW
18:39:11 T:3043655680 NOTICE: GL_VERSION = OpenGL ES 2.0
18:39:11 T:3043655680 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
18:39:11 T:3043655680 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
18:39:11 T:3032478816 ERROR: CecLogMessage - failed to release the previous LA
18:39:11 T:3032478816 ERROR: CecLogMessage - could not open a connection (try 1)
18:39:16 T:3043655680 NOTICE: Running database version Addons15
18:39:16 T:3043655680 NOTICE: Running database version ViewModes4
18:39:16 T:3043655680 NOTICE: Running database version Textures13
18:39:17 T:3043655680 NOTICE: Running database version MyMusic32
18:39:17 T:3043655680 NOTICE: Running database version MyVideos75
18:39:17 T:3043655680 NOTICE: Running database version TV22
18:39:17 T:3043655680 NOTICE: Running database version Epg7
18:39:17 T:3043655680 NOTICE: start dvd mediatype detection
18:39:17 T:3043655680 NOTICE: initializing playlistplayer
18:39:17 T:3043655680 NOTICE: DONE initializing playlistplayer
18:39:17 T:3033597024 NOTICE: Thread CDetectDVDMedia start, auto delete: false
18:39:23 T:2952852576 NOTICE: Thread CEC Adapter Update Thread start, auto delete: false
18:39:24 T:3043655680 NOTICE: initialize done
18:39:24 T:3043655680 NOTICE: Running the application...
18:39:25 T:3043655680 ERROR: GLES: Vertical Blank Syncing unsupported
18:39:28 T:2944463968 NOTICE: Thread Jobworker start, auto delete: true
18:39:28 T:3043655680 NOTICE: Webserver: Starting...
18:39:28 T:3043655680 NOTICE: WebServer: Started the webserver
18:39:28 T:3043655680 NOTICE: starting upnp server
18:39:29 T:3043655680 NOTICE: starting upnp renderer
18:39:29 T:3043655680 NOTICE: ES: Starting event server
18:39:29 T:2852189280 NOTICE: Thread CEventServer start, auto delete: false
18:39:29 T:2852189280 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:39:29 T:2852189280 NOTICE: UDP: Listening on port 9777
18:39:29 T:2843800672 NOTICE: Thread Jobworker start, auto delete: true
18:39:29 T:3043655680 ERROR: JSONRPC Server: Failed to connect to sdpd
18:39:29 T:3043655680 NOTICE: starting zeroconf publishing
18:39:29 T:2835412064 NOTICE: Thread CTCPServer start, auto delete: false
18:39:29 T:2827023456 NOTICE: Thread AirPlayServer start, auto delete: false
18:39:29 T:2818634848 NOTICE: Thread Jobworker start, auto delete: true
18:39:29 T:2810160224 NOTICE: Thread AirTunesServer start, auto delete: false
18:39:30 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
18:39:37 T:2801239136 NOTICE: Thread Jobworker start, auto delete: true
18:39:40 T:2792850528 NOTICE: Thread Background Loader start, auto delete: false
18:39:47 T:3043655680 NOTICE: Previous line repeats 3 times.
18:39:47 T:3043655680 NOTICE: COMXPlayer: Opening: smb://DISKSTATION/SynNoBackup/TV Shows/The Big Bang Theory/The Big Bang Theory.S01E01.mkv
18:39:47 T:3043655680 NOTICE: CXBMCRenderManager::ResetRenderBuffer - using 5 render buffers
18:39:47 T:2792850528 NOTICE: Thread COMXPlayer start, auto delete: false
18:39:47 T:2792850528 NOTICE: Creating InputStream
18:39:47 T:2792850528 NOTICE: Creating Demuxer
18:39:54 T:2792850528 NOTICE: Opening video stream: 0 source: 256
18:39:54 T:2792850528 NOTICE: OMXClock using video as reference
18:39:54 T:2792850528 NOTICE: Creating video thread
18:39:54 T:2761446496 NOTICE: Thread COMXPlayerVideo start, auto delete: false
18:39:54 T:2792850528 NOTICE: Opening audio stream: 1 source: 256
18:39:54 T:2792850528 NOTICE: Creating audio thread
18:39:54 T:2772391008 NOTICE: Thread COMXPlayerAudio start, auto delete: false
18:39:54 T:2761446496 ERROR: Output - renderer not started
18:39:54 T:2772391008 NOTICE: OMXClock using audio as reference
18:39:55 T:2761446496 ERROR: Output - renderer not started
18:39:55 T:2761446496 ERROR: Previous line repeats 5 times.
18:39:55 T:2761446496 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
18:39:55 T:2761446496 NOTICE: CXBMCRenderManager::ResetRenderBuffer - using 5 render buffers
18:39:55 T:3043655680 NOTICE: Using GL_TEXTURE_2D
18:39:55 T:3043655680 NOTICE: GL: Using BYPASS render method
18:39:55 T:3043655680 NOTICE: GL: NPOT texture support detected
18:40:03 T:2792850528 NOTICE: COMXPlayer::OnExit()
18:40:03 T:2792850528 NOTICE: OMXPlayer: closing audio stream
18:40:03 T:2792850528 NOTICE: Closing audio stream
18:40:03 T:2772391008 NOTICE: thread end: OMXPlayerAudio::OnExit()
18:40:03 T:2792850528 NOTICE: OMXClock using video as reference
18:40:03 T:2792850528 NOTICE: OMXPlayer: closing video stream
18:40:03 T:2792850528 NOTICE: Closing video stream
18:40:03 T:2761446496 NOTICE: thread end: video_thread
18:40:03 T:2792850528 NOTICE: COMXPlayer::OnExit() deleting demuxer
18:40:03 T:2792850528 NOTICE: COMXPlayer::OnExit() deleting input stream
18:40:04 T:2792850528 NOTICE: Thread Background Loader start, auto delete: false
18:40:05 T:3043655680 NOTICE: Previous line repeats 1 times.
18:40:05 T:3043655680 NOTICE: OMXClock using video as reference
18:40:07 T:2792850528 NOTICE: Previous line repeats 1 times.
18:40:07 T:2792850528 NOTICE: Thread Background Loader start, auto delete: false
18:40:15 T:3043655680 NOTICE: Previous line repeats 1 times.
18:40:15 T:3043655680 NOTICE: COMXPlayer: Opening: smb://DISKSTATION/SynNoBackup/Movies/Curious.George.Swings.Into.Spring.2013.DVDRIP.XVID-SMOKEY[rarbg]/smokey-curiousgsis.avi
18:40:16 T:3043655680 NOTICE: CXBMCRenderManager::ResetRenderBuffer - using 5 render buffers
18:40:16 T:2772391008 NOTICE: Thread COMXPlayer start, auto delete: false
18:40:16 T:2772391008 NOTICE: Creating InputStream
18:40:16 T:2772391008 NOTICE: Creating Demuxer
18:40:17 T:2772391008 NOTICE: Opening video stream: 0 source: 256
18:40:17 T:2772391008 NOTICE: OMXClock using video as reference
18:40:17 T:2772391008 NOTICE: Creating video thread
18:40:17 T:2780779616 NOTICE: Thread COMXPlayerVideo start, auto delete: false
18:40:17 T:2772391008 NOTICE: Opening audio stream: 1 source: 256
18:40:17 T:2772391008 NOTICE: Creating audio thread
18:40:17 T:2761446496 NOTICE: Thread COMXPlayerAudio start, auto delete: false
18:40:18 T:2761446496 NOTICE: OMXClock using audio as reference
18:40:18 T:2780779616 ERROR: Output - renderer not started
18:40:18 T:2780779616 ERROR: Previous line repeats 8 times.
18:40:18 T:2780779616 NOTICE: Display resolution DESKTOP : 1920x1080 @ 60.00 - Full Screen (16)
18:40:18 T:2780779616 NOTICE: CXBMCRenderManager::ResetRenderBuffer - using 5 render buffers
18:40:19 T:3043655680 NOTICE: Using GL_TEXTURE_2D
18:40:19 T:3043655680 NOTICE: GL: Using BYPASS render method
18:40:19 T:3043655680 NOTICE: GL: NPOT texture support detected
19:16:05 T:2772391008 NOTICE: COMXPlayer::OnExit()
19:16:05 T:2772391008 NOTICE: OMXPlayer: eof, waiting for queues to empty
19:16:05 T:2772391008 NOTICE: OMXPlayer: closing audio stream
19:16:05 T:2772391008 NOTICE: Closing audio stream
19:16:05 T:2772391008 NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
19:16:05 T:2761446496 NOTICE: thread end: OMXPlayerAudio::OnExit()
19:16:05 T:2772391008 NOTICE: OMXClock using video as reference
19:16:05 T:2772391008 NOTICE: OMXPlayer: closing video stream
19:16:05 T:2772391008 NOTICE: Closing video stream
19:16:05 T:2772391008 NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
19:16:05 T:2780779616 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
19:16:05 T:2780779616 NOTICE: thread end: video_thread
19:16:05 T:2772391008 NOTICE: COMXPlayer::OnExit() deleting demuxer
19:16:05 T:2772391008 NOTICE: COMXPlayer::OnExit() deleting input stream
19:16:05 T:2772391008 NOTICE: Thread Jobworker start, auto delete: true
19:16:06 T:3033597024 NOTICE: Previous line repeats 1 times.
19:16:06 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
19:16:06 T:3043655680 NOTICE: OMXClock using video as reference
19:17:39 T:3043655680 NOTICE: Previous line repeats 1 times.
19:17:39 T:3043655680 NOTICE: Samba is idle. Closing the remaining connections
19:47:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
00:36:14 T:2747225184 NOTICE: Previous line repeats 9 times.
00:36:14 T:2747225184 NOTICE: Thread Jobworker start, auto delete: true
00:36:14 T:2801640544 NOTICE: Thread CFileCache start, auto delete: false
00:57:00 T:3033597024 NOTICE: Previous line repeats 1 times.
00:57:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
06:36:25 T:2801640544 NOTICE: Previous line repeats 10 times.
06:36:25 T:2801640544 NOTICE: Thread Jobworker start, auto delete: true
06:36:25 T:2818634848 NOTICE: Thread CFileCache start, auto delete: false
06:38:00 T:3033597024 NOTICE: Previous line repeats 1 times.
06:38:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
12:36:35 T:2793251936 NOTICE: Previous line repeats 11 times.
12:36:35 T:2793251936 NOTICE: Thread Jobworker start, auto delete: true
12:36:35 T:2780779616 NOTICE: Thread CFileCache start, auto delete: false
12:50:00 T:3033597024 NOTICE: Previous line repeats 1 times.
12:50:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
18:36:45 T:2843800672 NOTICE: Previous line repeats 11 times.
18:36:45 T:2843800672 NOTICE: Thread Jobworker start, auto delete: true
18:36:45 T:2772391008 NOTICE: Thread CFileCache start, auto delete: false
19:02:00 T:3033597024 NOTICE: Previous line repeats 1 times.
19:02:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
00:46:53 T:2793251936 NOTICE: Previous line repeats 11 times.
00:46:53 T:2793251936 NOTICE: Thread Jobworker start, auto delete: true
00:46:54 T:2801640544 NOTICE: Thread CFileCache start, auto delete: false
01:14:00 T:3033597024 NOTICE: Previous line repeats 1 times.
01:14:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
06:47:03 T:2801640544 NOTICE: Previous line repeats 10 times.
06:47:03 T:2801640544 NOTICE: Thread Jobworker start, auto delete: true
06:47:03 T:2730447968 NOTICE: Thread CFileCache start, auto delete: false
06:55:00 T:3033597024 NOTICE: Previous line repeats 1 times.
06:55:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
12:57:12 T:2755613792 NOTICE: Previous line repeats 11 times.
12:57:12 T:2755613792 NOTICE: Thread Jobworker start, auto delete: true
12:57:12 T:2780779616 NOTICE: Thread CFileCache start, auto delete: false
13:07:00 T:3033597024 NOTICE: Previous line repeats 1 times.
13:07:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
15:42:20 T:3033597024 NOTICE: Previous line repeats 5 times.
15:42:20 T:3033597024 WARNING: FillBuffer: curl failed with code 28
15:42:20 T:3033597024 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
15:42:20 T:3033597024 ERROR: Timeout whilst retrieving http://openelec.tv/news?format=feed&type=rss
16:13:00 T:3033597024 NOTICE: Thread CRssReader start, auto delete: false
18:59:13 T:2780779616 NOTICE: Previous line repeats 5 times.
18:59:13 T:2780779616 NOTICE: Thread Jobworker start, auto delete: true
18:59:19 T:3043655680 ERROR: Error: Requested setting (videoscreen.screen) was not found. It must be case-sensitive
18:59:24 T:3043655680 ERROR: Previous line repeats 2 times.
18:59:24 T:3043655680 NOTICE: Log level changed to 2
18:59:24 T:3043655680 NOTICE: Enabled debug logging due to GUI setting. Level 2.
18:59:24 T:3043655680 DEBUG: ------ Window Init () ------
18:59:25 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
18:59:25 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:27 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:27 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:28 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:31 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
18:59:31 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:31 T:3043655680 DEBUG: Keyboard: scancode: 0e, sym: 0008, unicode: 0008, modifier: 0
18:59:31 T:3043655680 DEBUG: OnKey: backspace (f008) pressed, action is Back
18:59:31 T:3043655680 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
18:59:31 T:3043655680 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
18:59:31 T:3043655680 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
18:59:31 T:3043655680 DEBUG: ------ Window Init (Settings.xml) ------
18:59:31 T:3043655680 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x025e4348 dllopen : 1
18:59:31 T:3043655680 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:31 T:3043655680 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x0242a3e8 dllopen : 1
18:59:31 T:3043655680 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:31 T:3043655680 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:31 T:3043655680 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(3686400) nBufferAlignmen(16)
18:59:31 T:3043655680 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x0242a3e8 dllopen : 1
18:59:31 T:3043655680 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x025e4348 dllopen : 1
18:59:31 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x024b3788 dllopen : 1
18:59:31 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:31 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x02851f20 dllopen : 1
18:59:31 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:31 T:2780779616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:31 T:2780779616 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(2097152) nBufferAlignmen(16)
18:59:32 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x02851f20 dllopen : 1
18:59:32 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x024b3788 dllopen : 1
18:59:32 T:2780779616 DEBUG: DoWork - took 181 ms to load special://skin/backgrounds/settings.jpg
18:59:32 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:32 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:33 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:36 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
18:59:36 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:37 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:37 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:38 T:3043655680 DEBUG: Keyboard: scancode: 0e, sym: 0008, unicode: 0008, modifier: 0
18:59:38 T:3043655680 DEBUG: OnKey: backspace (f008) pressed, action is Back
18:59:38 T:3043655680 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
18:59:38 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:38 T:3043655680 DEBUG: ------ Window Deinit (Settings.xml) ------
18:59:38 T:3043655680 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
18:59:38 T:3043655680 DEBUG: ------ Window Init (Home.xml) ------
18:59:38 T:2780779616 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
18:59:38 T:3043655680 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x02fcdb10 dllopen : 1
18:59:38 T:3043655680 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:38 T:3043655680 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x02486c18 dllopen : 1
18:59:38 T:3043655680 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:38 T:3043655680 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:38 T:2780779616 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
18:59:38 T:2780779616 DEBUG: GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
18:59:38 T:3043655680 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(3686400) nBufferAlignmen(16)
18:59:38 T:3043655680 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x02486c18 dllopen : 1
18:59:38 T:3043655680 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x02fcdb10 dllopen : 1
18:59:38 T:2780779616 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
18:59:38 T:2780779616 DEBUG: RunQuery took 15 ms for 10 items query: select * from movieview ORDER BY dateAdded desc, idMovie desc LIMIT 10
18:59:38 T:2764002400 NOTICE: Thread Jobworker start, auto delete: true
18:59:39 T:2780779616 DEBUG: RunQuery took 9 ms for 10 items query: select * from episodeview ORDER BY dateAdded desc, idEpisode desc LIMIT 10
18:59:39 T:2780779616 DEBUG: RunQuery took 9 ms for 10 items query: select * from musicvideoview ORDER BY dateAdded desc, idMVideo desc LIMIT 10
18:59:39 T:2780779616 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
18:59:41 T:3043655680 DEBUG: Keyboard: scancode: 69, sym: 0114, unicode: 0000, modifier: 0
18:59:41 T:3043655680 DEBUG: OnKey: left (f082) pressed, action is Left
18:59:41 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
18:59:41 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:42 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:42 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:42 T:3043655680 DEBUG: Keyboard: scancode: 69, sym: 0114, unicode: 0000, modifier: 0
18:59:42 T:3043655680 DEBUG: OnKey: left (f082) pressed, action is Left
18:59:43 T:3043655680 DEBUG: Keyboard: scancode: 69, sym: 0114, unicode: 0000, modifier: 0
18:59:43 T:3043655680 DEBUG: OnKey: left (f082) pressed, action is Left
18:59:43 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:44 T:3043655680 DEBUG: Keyboard: scancode: 6c, sym: 0112, unicode: 0000, modifier: 0
18:59:44 T:3043655680 DEBUG: OnKey: down (f081) pressed, action is Down
18:59:44 T:3043655680 DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 0000, modifier: 0
18:59:45 T:3043655680 DEBUG: OnKey: return (f00d) pressed, action is Select
18:59:45 T:3043655680 DEBUG: ExecuteXBMCAction : Translating ActivateWindow(Videos,MusicVideoTitles,return)
18:59:45 T:3043655680 DEBUG: ExecuteXBMCAction : To ActivateWindow(Videos,MusicVideoTitles,return)
18:59:45 T:3043655680 DEBUG: Activating window ID: 10025
18:59:45 T:3043655680 DEBUG: ------ Window Deinit (Home.xml) ------
18:59:45 T:3043655680 DEBUG: ExecuteXBMCAction : Translating SetProperty(VideosDirectLink,True)
18:59:45 T:3043655680 DEBUG: ExecuteXBMCAction : To SetProperty(VideosDirectLink,True)
18:59:45 T:3043655680 DEBUG: ------ Window Init (MyVideoNav.xml) ------
18:59:45 T:3043655680 DEBUG: CGUIMediaWindow::GetDirectory (videodb://3/2/)
18:59:45 T:3043655680 DEBUG: ParentPath = [videodb://3/2/]
18:59:45 T:3043655680 DEBUG: RunQuery took 13 ms for 33 items query: select * from musicvideoview
18:59:45 T:2818634848 NOTICE: Thread Background Loader start, auto delete: false
18:59:45 T:2764002400 DEBUG: DoWork - trying to extract filestream details from video file smb://DISKSTATION/SynNoBackup/Music Videos/Chris Brown - Don't Wake Me Up.flv
18:59:45 T:2818634848 DEBUG: Thread Background Loader 2818634848 terminating
18:59:46 T:2843800672 NOTICE: Thread Background Loader start, auto delete: false
18:59:46 T:3043655680 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x02471550 dllopen : 1
18:59:46 T:3043655680 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:46 T:3043655680 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x0249b460 dllopen : 1
18:59:46 T:3043655680 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:46 T:3043655680 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:46 T:3043655680 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(3686400) nBufferAlignmen(16)
18:59:46 T:2843800672 DEBUG: Thread Background Loader 2843800672 terminating
18:59:46 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
18:59:46 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:46 T:3043655680 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x0249b460 dllopen : 1
18:59:46 T:3043655680 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x02471550 dllopen : 1
18:59:47 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x02fa30a8 dllopen : 1
18:59:47 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:47 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x01d8f5d0 dllopen : 1
18:59:47 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:47 T:2780779616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:47 T:2780779616 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
18:59:47 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x01d8f5d0 dllopen : 1
18:59:47 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x02fa30a8 dllopen : 1
18:59:47 T:2780779616 DEBUG: DoWork - took 219 ms to load special://masterprofile/Thumbnails/0/0d8bc851.jpg
18:59:47 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:47 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:47 T:2764002400 DEBUG: CSmbFile::Open - opened SynNoBackup/Music Videos/Chris Brown - Don't Wake Me Up.flv, fd=10000
18:59:47 T:2764002400 DEBUG: DllAvUtilBase: Using libavutil system library
18:59:47 T:2764002400 DEBUG: DllAvCodec: Using libavcodec system library
18:59:47 T:2764002400 DEBUG: DllAvFormat: Using libavformat system library
18:59:47 T:2764002400 DEBUG: Open - probing detected format [flv]
18:59:47 T:2764002400 DEBUG: ffmpeg[A4BF5460]: [flv] Broken FLV file, which says no streams present, this might fail
18:59:47 T:2764002400 DEBUG: Open - avformat_find_stream_info starting
18:59:48 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:49 T:3043655680 DEBUG: Keyboard: scancode: 6c, sym: 0112, unicode: 0000, modifier: 0
18:59:49 T:3043655680 DEBUG: OnKey: down (f081) pressed, action is Down
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x0248b9a8 dllopen : 1
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x024d2440 dllopen : 1
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
18:59:50 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x024d2440 dllopen : 1
18:59:50 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x0248b9a8 dllopen : 1
18:59:50 T:2780779616 DEBUG: DoWork - took 123 ms to load special://masterprofile/Thumbnails/5/5fe1f7d1.jpg
18:59:50 T:3043655680 DEBUG: Keyboard: scancode: 6c, sym: 0112, unicode: 0000, modifier: 0
18:59:50 T:3043655680 DEBUG: OnKey: down (f081) pressed, action is Down
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x02f96118 dllopen : 1
18:59:50 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x03011b60 dllopen : 1
18:59:50 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x03011b60 dllopen : 1
18:59:50 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x02f96118 dllopen : 1
18:59:50 T:2780779616 DEBUG: DoWork - took 104 ms to load special://masterprofile/Thumbnails/7/75c1f92c.jpg
18:59:51 T:3043655680 DEBUG: Keyboard: scancode: 6c, sym: 0112, unicode: 0000, modifier: 0
18:59:51 T:3043655680 DEBUG: OnKey: down (f081) pressed, action is Down
18:59:51 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x0300e050 dllopen : 1
18:59:51 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:51 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x02eec4a8 dllopen : 1
18:59:51 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:51 T:2780779616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:51 T:2780779616 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
18:59:51 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x02eec4a8 dllopen : 1
18:59:51 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x0300e050 dllopen : 1
18:59:51 T:2780779616 DEBUG: DoWork - took 107 ms to load special://masterprofile/Thumbnails/d/d876d921.jpg
18:59:51 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
18:59:51 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:52 T:3043655680 DEBUG: Keyboard: scancode: 6c, sym: 0112, unicode: 0000, modifier: 0
18:59:52 T:3043655680 DEBUG: OnKey: down (f081) pressed, action is Down
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x02eec4a8 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x023bed60 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x023bed60 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x02eec4a8 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x023edcc8 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x027773b8 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x027773b8 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x023edcc8 dllopen : 1
18:59:52 T:2780779616 DEBUG: DoWork - took 135 ms to load special://masterprofile/Thumbnails/6/656354ad.jpg
18:59:52 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:52 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x027bb230 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x02fa5398 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x02fa5398 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x027bb230 dllopen : 1
18:59:52 T:2780779616 DEBUG: DoWork - took 124 ms to load special://masterprofile/Thumbnails/0/03ea0543.jpg
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x024d11e0 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x027b3100 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x027b3100 dllopen : 1
18:59:52 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x024d11e0 dllopen : 1
18:59:53 T:3043655680 DEBUG: Keyboard: scancode: 6c, sym: 0112, unicode: 0000, modifier: 0
18:59:53 T:3043655680 DEBUG: OnKey: down (f081) pressed, action is Down
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x0248b1b0 dllopen : 1
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x02fa26b8 dllopen : 1
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.resize input port 60 output port 61
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(3), nBufferSize(81920), nBufferAlignmen(16)
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::AllocOutputBuffers component(OMX.broadcom.resize) - port(61), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(262144) nBufferAlignmen(16)
18:59:53 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x02fa26b8 dllopen : 1
18:59:53 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x0248b1b0 dllopen : 1
18:59:53 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.image_decode handle 0x0247ea30 dllopen : 1
18:59:53 T:2780779616 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.resize handle 0x02803300 dllopen : 1
18:59:53 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.resize handle 0x02803300 dllopen : 1
18:59:53 T:2780779616 DEBUG: COMXCoreComponent:Big Grineinitialize : OMX.broadcom.image_decode handle 0x0247ea30 dllopen : 1
18:59:53 T:2780779616 DEBUG: DoWork - took 116 ms to load special://masterprofile/Thumbnails/8/8da5d0ba.jpg
18:59:54 T:3043655680 DEBUG: Keyboard: scancode: 67, sym: 0111, unicode: 0000, modifier: 0
18:59:54 T:3043655680 DEBUG: OnKey: up (f080) pressed, action is Up
18:59:55 T:3043655680 DEBUG: Keyboard: scancode: 1c, sym: 000d, unicode: 0000, modifier: 0
18:59:55 T:3043655680 DEBUG: OnKey: return (f00d) pressed, action is Select
18:59:55 T:3043655680 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
18:59:55 T:3043655680 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
18:59:55 T:3043655680 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
18:59:55 T:3043655680 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers(smb://DISKSTATION/SynNoBackup/Music Videos/Jay Sean - Down.flv)
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
18:59:56 T:3043655680 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (4)
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: OMXPlayer (4)
18:59:56 T:3043655680 DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
18:59:56 T:3043655680 NOTICE: COMXPlayer: Opening: smb://DISKSTATION/SynNoBackup/Music Videos/Jay Sean - Down.flv
18:59:56 T:3043655680 DEBUG: COMXCoreComponent::Initialize : OMX.broadcom.clock handle 0x02f7a3a8 dllopen : 1
18:59:56 T:3043655680 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81
18:59:56 T:3043655680 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
18:59:56 T:3043655680 NOTICE: CXBMCRenderManager::ResetRenderBuffer - using 5 render buffers
18:59:56 T:3043655680 DEBUG: LinuxRendererGL: Cleaning up GL resources
18:59:56 T:3043655680 DEBUG: DllSwScale: Using libswscale system library
18:59:56 T:2801640544 NOTICE: Thread COMXPlayer start, auto delete: false
18:59:56 T:2801640544 NOTICE: Creating InputStream
18:59:56 T:2801640544 DEBUG: CSmbFile::Open - opened SynNoBackup/Music Videos/Jay Sean - Down.flv, fd=10001
18:59:56 T:3043655680 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:59:56 T:2801640544 DEBUG: ScanForExternalSubtitles: Searching for subtitles...
18:59:56 T:2801640544 DEBUG: OpenDir - Using authentication url smb://DISKSTATION/SynNoBackup/Music%20Videos
18:59:56 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
18:59:56 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:57 T:2801640544 DEBUG: ScanForExternalSubtitles: END (total time: 1234 ms)
18:59:57 T:2801640544 NOTICE: Creating Demuxer
18:59:57 T:2801640544 DEBUG: DllAvUtilBase: Using libavutil system library
18:59:57 T:2801640544 DEBUG: DllAvCodec: Using libavcodec system library
18:59:57 T:2801640544 DEBUG: DllAvFormat: Using libavformat system library
18:59:57 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
18:59:57 T:2952852576 DEBUG: CecLogMessage - << 10:8f
18:59:58 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
19:00:01 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
19:00:01 T:2952852576 DEBUG: CecLogMessage - << 10:8f
19:00:02 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
19:00:02 T:2952852576 DEBUG: CecLogMessage - << 10:8f
19:00:04 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
19:00:07 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
19:00:07 T:2952852576 DEBUG: CecLogMessage - << 10:8f
19:00:08 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
19:00:08 T:2952852576 DEBUG: CecLogMessage - << 10:8f
19:00:09 T:2952852576 DEBUG: CecLogMessage - expected response not received (90: report power status)
19:00:12 T:2952852576 DEBUG: CecLogMessage - << requesting power status of 'TV' (0)
19:00:12 T:2952852576 DEBUG: CecLogMessage - << 10:8f
And this repeats forever
