Yes, same error
Windows 8, XBMC gotham, skin ace
4:18:22 T:5964 NOTICE: -----------------------------------------------------------------------
14:18:22 T:5964 NOTICE: Starting XBMC 13, Platform: Windows 8 32-bit, build 7600. Built on Apr 29 2013 (compiler 1600)
14:18:22 T:5964 NOTICE: Intel® Pentium® CPU G620 @ 2.60GHz
14:18:22 T:5964 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
14:18:22 T:5964 NOTICE: Running with administrator rights
14:18:22 T:5964 NOTICE: Aero is enabled
14:18:22 T:5964 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
14:18:22 T:5964 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
14:18:22 T:5964 NOTICE: special://masterprofile/ is mapped to: C:\Users\Wanilton\AppData\Roaming\XBMC\userdata
14:18:22 T:5964 NOTICE: special://home/ is mapped to: C:\Users\Wanilton\AppData\Roaming\XBMC\
14:18:22 T:5964 NOTICE: special://temp/ is mapped to: C:\Users\Wanilton\AppData\Roaming\XBMC\cache
14:18:22 T:5964 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
14:18:22 T:5964 NOTICE: Local hostname: HTPC
14:18:22 T:5964 NOTICE: Log File is located: C:\Users\Wanilton\AppData\Roaming\XBMC\xbmc.log
14:18:22 T:5964 NOTICE: -----------------------------------------------------------------------
14:21:00 T:7876 NOTICE: -->Python Interpreter Initialized<--
14:21:01 T:7876 NOTICE: ARGV Parameters: ['plugin://plugin.audio.sonora/', '1', '']
14:21:01 T:7876 NOTICE: CommonFunctions-2.5.1
14:21:02 T:7876 NOTICE: [Sonora] URL:
http://webservices.sonora.terra.com.br/G...version=10
14:21:03 T:7876 NOTICE: [Sonora] URL:
http://webservices.sonora.terra.com.br/U...ord=Cenpro
14:21:03 T:7876 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'str' object has no attribute 'result'
File "C:\Users\Wanilton\AppData\Roaming\XBMC\addons\plugin.audio.sonora\default.py", line 61, in <module>
login.login()
File "C:\Users\Wanilton\AppData\Roaming\XBMC\addons\plugin.audio.sonora\SonoraLogin.py", line 54, in login
result, status = self.core.account_auth(username, userpassword)
File "C:\Users\Wanilton\AppData\Roaming\XBMC\addons\plugin.audio.sonora\SonoraCore.py", line 103, in account_auth
result = 'Account authentication failed: ' . result['messageText']
AttributeError: 'str' object has no attribute 'result'
14:21:03 T:5964 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.audio.sonora
14:21:03 T:5964 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.sonora) failed
14:21:04 T:10148 NOTICE: Thread BackgroundLoader start, auto delete: false
14:21:08 T:1960 NOTICE: Thread XBPython start, auto delete: false
