Full Version: I wanna talk smb problems.
My PC running PC-BSD
samba36 is installed on my os.
The xbmc package is dependent on samba36-nmblookup,
and samba36-nmblookup conflicts with samba36.
The only method I can install that package is delete samba36, install xbmc, delete samba36-nmblookup then install samba36.
the xbmc works well wtih samba36!
What happened? Can you guys remove the dependency of samba36-nmblookup?
or give a option to choose one of both?
Looks like a BSD packaging problem.
you should probably contact the BSD package maintainer.
