Full Version: Keyboard.xml or joystick.filename.xml not load during XBMC boot
I'm try to configure my remote device in XBMC, but seem that it doesn't load the .xml during the boot.
I copied my file into /home/pi/.xbmc/userdata/keymaps
File name:
joystick.Fujitsu.xml
File content:
http://pastebin.com/eiFRJj1g
This is the LOG:
http://pastebin.com/Z0uxbEqn
I have the same result if I put keyboard.xml in the same path.
I try too to put the .xml file in /opt/xbmc-bcm/xbmc-bin/share/xbmc/system/keymaps with no results.
Please help me because I'm going crazy.....
Thank you
