Full Version: Tips on setup: resolution and other
I've been using a Pivos AIOS media extender for the last 15 months. It's a good device, except for my speakers popping at each pause/unpause when watching content with any 5.1 encoded content. 2 channel = no popping. Anyway, I wanted to try XBMC, so here I am.
98% of my content is 720p. Of the remaining 2%, 1.8% is 1080p, and the rest is SD. The issue I'm having is choosing the correct resolution on my tv that does not alter the aspect ratio of the content when playback begins. Most content is 16:9, others are 2.35:1, 2.55:1, 4:3, etc. I want all content to display as fullscreen as is possible without input from me and without altering the content. The Pivos does this, no matter what the source resolution. For playback, do I choose normal, stretch 16:9 for 16:9 content, something else for 4:3 content, etc? Does playback setting change depending on the resolution of the content? Should I alter the display's resolution depending on the content?
XBMC 12.1 Git:20130317-0d30317-0d373cc
Windows XP Pro, SP3 32 bit, build 2600
AMD Athlon II X2 Regor, 64 bit
2GB RAM
ATI Radeon 3000 onboard graphics, 6.14.10.7267, 1920x1080 @ 60hZ
Realtek onboard sound, 5.10.0.6519
Panasonic TC-P50s30
XBMC 12.1 Git
http://pastebin.com/TiUH8Fak
General
Complete name : Y:\Burn.Notice\burn.notice.s05e07.besieged.720p.web.dl.dd5.1.h264.kings.mkv
Format : Matroska
File size : 1.31 GiB
Duration : 43mn 12s
Overall bit rate : 4 337 Kbps
Encoded date : UTC 2011-08-05 09:38:57
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 12s
Bit rate mode : Variable
Bit rate : 3 867 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.175
Stream size : 1.17 GiB (89%)
Title : Burn.Notice.S05E07.720p.WEB-DL.DD5.1.H.264-KiNGS
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 43mn 12s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 119 MiB (9%)
Language : English
If most of your content is 720p, there should not be any issues but you might have black borders depending on the aspect. If you want to ensure NO black borders then use the zoom tool or optional rotate the presets with the z key (I guess you'll have to program that into the remote keymap). Once you pick an aspect or zoom for a particular film XBMC retains that setting for the film. Other sized content like 1080p or 480i etc will be adjusted to fit whatever parameters you have set for videos. (using the OSD while playing video, enter the video settings tool 'the projector icon' and adjust your video calibration, and save as default for all videos).
The Z key mapped to your remote for the most part, should meet your needs, try it from the keyboard.
